* | libtest: Change expected pass state string | Sebastian Huber | 2019-12-05 | 1 | -1/+1 |
| | | | | Use separator character '_' for all test states. | ||||
* | score: Optimize object lookup | Sebastian Huber | 2018-12-07 | 1 | -20/+218 |
| | | | | | | | | | | | | | | | | Use the maximum ID for the ID to object translation. Using the maximum ID gets rid of an additional load from the object information in _Objects_Get(). In addition, object lookups fail for every ID in case the object information is cleared to zero. This makes it a bit more robust during system startup (see new tests in spconfig02). The local table no longer needs a NULL pointer entry at array index zero. Adjust all the object iteration loops accordingly. Remove Objects_Information::minimum_id since it contains only redundant information. Add _Objects_Get_minimum_id() to get the minimum ID. Update #3621. | ||||
* | spconfig02: Check object methods in default config | Sebastian Huber | 2018-11-07 | 3 | -0/+318 |
Ensure that the creation of Classic API objects fails with the expected status code in the default configuration. Ensure that the deletion of Classic API objects fails with the expected status code in the default configuration if the identifier is invalid. Ensure that only the expected objects are present in the default configuration via rtems_object_get_classic_name(). |
