* | libtest: Change expected pass state string | Sebastian Huber | 2019-12-05 | 1 | -1/+1 |
| | | | | Use separator character '_' for all test states. | ||||
* | config: Modify CONFIGURE_INTERRUPT_STACK_SIZE | Sebastian Huber | 2018-10-24 | 1 | -0/+32 |
| | | | | | | | Use CPU_STACK_MINIMUM_SIZE instead of CONFIGURE_MINIMUM_TASK_STACK_SIZE to set the default value. Close #3480. | ||||
* | sptests/spconfig01: New test | Sebastian Huber | 2018-09-06 | 3 | -0/+140 |
Close #3435. |
