* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -0/+2 |
* | 2011-10-04 Sebastian Huber <sebastian.huber@embedded-brains.de> | Jennifer Averett | 2011-10-04 | 1 | -5/+5 |
| | | | | | | | PR 1922 * spcbssched02/system.h, spcbssched03/system.h, spedfsched02/system.h, spedfsched02/task1.c, spedfsched03/system.h: EDF and CBS scheduler: extern declarations fix. | ||||
* | 2011-09-26 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-27 | 1 | -2/+2 |
| | | | | | | | PR 1923/testing * spcbssched02/spcbssched02.scn, spcbssched02/system.h, spcbssched03/init.c, spcbssched03/system.h, spedfsched02/system.h, spedfsched03/system.h, sprbtree01/init.c: Improve coverage. | ||||
* | 2011-09-15 Petr Benes <benesp16@fel.cvut.cz> | Joel Sherrill | 2011-09-15 | 1 | -0/+73 |
PR 1907/testing * Makefile.am, configure.ac: Add tests for the CBS (Constant Bandwidth Server) scheduler. * spcbssched01/.cvsignore, spcbssched01/Makefile.am, spcbssched01/init.c, spcbssched01/spcbssched01.doc, spcbssched01/spcbssched01.scn, spcbssched01/system.h, spcbssched01/task1.c, spcbssched02/.cvsignore, spcbssched02/Makefile.am, spcbssched02/init.c, spcbssched02/spcbssched02.doc, spcbssched02/spcbssched02.scn, spcbssched02/system.h, spcbssched02/task_periodic.c, spcbssched03/.cvsignore, spcbssched03/Makefile.am, spcbssched03/cbsparams.h, spcbssched03/init.c, spcbssched03/spcbssched03.doc, spcbssched03/spcbssched03.scn, spcbssched03/system.h, spcbssched03/tasks_aperiodic.c, spcbssched03/tasks_periodic.c: New files. |
