Avoid uninitialized stack variable. This is not a proper fix. It is
not clear what the task should do if argument != 1.
* sp75/init.c, spcbssched01/init.c, spcbssched01/task1.c
spcbssched02/init.c, spcbssched02/task_periodic.c,
spcbssched03/init.c, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c, spedfsched01/init.c,
spedfsched01/task1.c, spedfsched02/getall.c, spedfsched02/init.c,
spedfsched02/task1.c, spedfsched03/init.c,
spedfsched03/tasks_aperiodic.c, spedfsched03/tasks_periodic.c,
sprbtree01/init.c: Add HAVE_CONFIG_H.
PR 1916/testing
* spcbssched02/init.c, spcbssched02/spcbssched02.scn,
spcbssched02/system.h, spcbssched02/task_periodic.c,
spedfsched03/init.c, spedfsched03/system.h,
spedfsched03/tasks_aperiodic.c: Improve coverage.
PR 1907/testing
* Makefile.am, configure.ac: Add tests for the CBS (Constant Bandwidth
Server) scheduler.
* spcbssched01/.cvsignore, spcbssched01/Makefile.am,
spcbssched01/init.c, spcbssched01/spcbssched01.doc,
spcbssched01/spcbssched01.scn, spcbssched01/system.h,
spcbssched01/task1.c, spcbssched02/.cvsignore,
spcbssched02/Makefile.am, spcbssched02/init.c,
spcbssched02/spcbssched02.doc, spcbssched02/spcbssched02.scn,
spcbssched03/.cvsignore, spcbssched03/Makefile.am,
spcbssched03/cbsparams.h, spcbssched03/init.c,
spcbssched03/spcbssched03.doc, spcbssched03/spcbssched03.scn,
spcbssched03/system.h, spcbssched03/tasks_aperiodic.c,
spcbssched03/tasks_periodic.c: New files.
