* | bsps/testsuites/: Scripted embedded brains header file clean up | Joel Sherrill | 2022-03-10 | 1 | -6/+0 |
| | | | | Updates #4625. | ||||
* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -19/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | score: Use uintptr_t for atomic pointer operations | Sebastian Huber | 2015-09-26 | 2 | -48/+120 |
| | | | | Do not obfuscate the standard API. | ||||
* | score: Fix atomic compare exchange | Sebastian Huber | 2015-09-25 | 1 | -16/+49 |
* | sptests/spatomic01/init.c: Avoid integer overflow | Joel Sherrill | 2015-03-24 | 1 | -8/+11 |
* | score: Make <rtems/score/atomic.h> available | Sebastian Huber | 2015-02-19 | 4 | -0/+319 |
| | | | | | | | | Make <rtems/score/atomic.h> available for all RTEMS configurations. Use inline functions instead of macros. Use ISR disable/enable on uni-processor configurations to ensure atomicity. Update #2273. | ||||
* | clean up spatomic testcase | WeiY | 2013-08-01 | 6 | -324/+0 |
* | stdatomic.h support check when configure | WeiY | 2013-07-17 | 1 | -0/+4 |
* | spatomic test case update | WeiY | 2013-07-17 | 1 | -20/+13 |
* | Clear the atomic conditional compilation. | WeiY | 2013-05-01 | 1 | -4/+0 |
* | Introduce AM_CONDITIONAL ATOMIC. | Ralf Corsépius | 2013-02-14 | 1 | -2/+4 |
* | tests: atomic support for RTEMS. Uniprocessor tests for atomic ops. | WeiY | 2013-02-07 | 6 | -0/+329 |
