* | testsuites/sptests/sp[0-7]*/*.doc: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | score: Improve _CORE_message_queue_Initialize() | Sebastian Huber | 2020-09-28 | 1 | -1/+1 |
| | | | | | | Return a status code and differentiate between error conditions. Update #4007. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Cleanup Krzysztof's copyright notices. | Ralf Corsépius | 2012-10-11 | 2 | -2/+2 |
* | sp77: new test to cover allocated message size overflowing | Krzysztof Mięsowicz | 2012-08-29 | 4 | -0/+100 |
Author: Krzysztof Mięsowicz <krzysztof.miesowicz@gmail.com> |
