2017-01-26 | Remove rtems_rate_monotonic_postponed_job_count() | Kuan-Hsun Chen | 1 | -0/+2 | |
Add a variable named "count" in rtems_rate_monotonic_period_status structure. Revise rtems_rate_monotonic_get_status() for the postponed job count. sptests/sp69: Add in the verification of the postponed job count for rtems_rate_monotonic_get_status(). Update #2795. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-12-10 | 2009-12-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -0/+1 | |
* sp69/init.c, sp69/sp69.doc, sp69/sp69.scn: Add test for statistics on expired periods. This detected the recently introduced PR1480. | |||||
2009-12-08 | 2009-12-08 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 1 | -8/+7 | |
* Makefile.am, configure.ac: Added a test for rate_monotonic_get_status to ensure that all paths are tested. * sp69/Makefile.am, sp69/init.c, sp69/sp69.doc, sp69/sp69.scn: New files. | |||||
2009-07-16 | 2009-07-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -6/+8 | |
* Makefile.am, configure.ac: Add test for auto initialization of message queues. * psxautoinit02/.cvsignore, psxautoinit02/Makefile.am, psxautoinit02/init.c, psxautoinit02/psxautoinit02.doc, psxautoinit02/psxautoinit02.scn: New files. | |||||
2009-07-02 | 2009-07-02 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -3/+6 | |
* Makefile.am, configure.ac: Add new test for user configured stack allocator/deallocator. Test both pass and fail cases. * spstkalloc/.cvsignore, spstkalloc/Makefile.am, spstkalloc/init.c, spstkalloc/spstkalloc.doc, spstkalloc/spstkalloc.scn: New files. | |||||
2009-06-24 | 2009-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -3/+2 | |
* spfatal10/.cvsignore, spfatal10/Makefile.am, spfatal10/init.c, spfatal10/spfatal10.doc, spfatal10/spfatal10.scn: New files. | |||||
2009-06-24 | 2009-06-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -5/+4 | |
* Makefile.am, configure.ac, spprintk/init.c, spprintk/spprintk.scn: Enhance spprintk. Add two new fatal error tests to cover __assert_func. * spfatal11/.cvsignore, spfatal11/Makefile.am, spfatal11/init.c, spfatal11/spfatal11.doc, spfatal11/spfatal11.scn: New files. | |||||
2009-05-21 | 2009-05-21 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -5/+6 | |
PR 1413/cpukit * Makefile.am, configure.ac: Add test for case where server based timers which reinitiated themselves did not get reinserted onto timer chain. * sp50/.cvsignore, sp50/Makefile.am, sp50/init.c, sp50/sp50.doc, sp50/sp50.scn: New files. | |||||
2008-12-03 | 2008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -1/+4 | |
PR 1347/cpukit * Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c: Rework Timer Server to ensure that the context allows for blocking, allocating memory, and acquiring semaphores and mutexes. * sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn: New files. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed. | |||||
2002-01-16 | 2001-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* Added tests for task-based timers. This included the new tests sp30 and sp31. * Makefile.am, configure.ac: Modified to reflect new tests and files. * sp09/screen14.c, sp09/sp09.scn: Modified to add error checks for task-based timer services. * sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c, sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h, sp31/task1.c: New files. | |||||
1999-11-17 | Updated copyright notice. | Joel Sherrill | 1 | -2/+1 | |
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 1 | -1/+1 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1 | -2/+2 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1 | -5/+5 | |
of switching to the modified GNU GPL. |
