* Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very
simple priority ceiling case that was previously only tested via the
POSIX API.
* sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc,
sp66/sp66.scn: New files.
* sp65/init.c: Remove stray print.
* sp65/sp65.doc: Add information on second case.
* sp65/init.c, sp65/sp65.doc, sp65/sp65.scn: Add new test case to
verify that obtaining a priority ceiling mutex when the calling
task's priority is the same as the priority ceiling is handled
correctly.
* sp65/init.c: Add semi-colon to end of rtems_semaphore_create call.
Change attributes to priority ceiling. Use directive_failed, not
assert. Configure a semaphore not a region.
* ChangeLog, Makefile.am, configure.ac: Add new test for some core
mutex cases.
* sp65/.cvsignore, sp65/Makefile.am, sp65/init.c, sp65/sp65.doc,
sp65/sp65.scn: New files.
