* | score: PR2179: Fix initially locked PCP mutexes | Sebastian Huber | 2014-05-23 | 1 | -0/+35 |
| | | | | | Elevate the priority of the creating task to the ceiling priority in case a semaphore is created as initially locked. | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -5/+5 |
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -3/+6 |
| | | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | #include <unistd.h> | Ralf Corsepius | 2010-04-03 | 1 | -0/+1 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -8/+8 |
* | Eliminate unused vars. | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | 2009-09-14 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-14 | 1 | -6/+15 |
| | | | | | | | | * Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very simple priority ceiling case that was previously only tested via the POSIX API. * sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc, sp66/sp66.scn: New files. | ||||
* | 2009-08-17 Santosh G Vattam <vattam.santosh@gmail.com> | Joel Sherrill | 2009-08-17 | 1 | -1/+0 |
| | | | | | * sp65/init.c: Remove stray print. * sp65/sp65.doc: Add information on second case. | ||||
* | 2009-08-13 Santosh G Vattam <vattam.santosh@gmail.com> | Joel Sherrill | 2009-08-14 | 1 | -5/+46 |
| | | | | | | | * sp65/init.c, sp65/sp65.doc, sp65/sp65.scn: Add new test case to verify that obtaining a priority ceiling mutex when the calling task's priority is the same as the priority ceiling is handled correctly. | ||||
* | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-12 | 1 | -9/+12 |
| | | | | | | * sp65/init.c: Add semi-colon to end of rtems_semaphore_create call. Change attributes to priority ceiling. Use directive_failed, not assert. Configure a semaphore not a region. | ||||
* | 2009-08-12 Santosh G Vattam <vattam.santosh@gmail.com> | Joel Sherrill | 2009-08-12 | 1 | -0/+54 |
* ChangeLog, Makefile.am, configure.ac: Add new test for some core mutex cases. * sp65/.cvsignore, sp65/Makefile.am, sp65/init.c, sp65/sp65.doc, sp65/sp65.scn: New files. |
