Update #3818.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3001.
Elevate the priority of the creating task to the ceiling priority in
case a semaphore is created as initially locked.
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* Makefile.am, configure.ac, sp65/init.c: Add new test to exercise very
simple priority ceiling case that was previously only tested via the
POSIX API.
* sp66/.cvsignore, sp66/Makefile.am, sp66/init.c, sp66/sp66.doc,
sp66/sp66.scn: New files.
* sp65/init.c: Remove stray print.
* sp65/sp65.doc: Add information on second case.
* sp65/init.c, sp65/sp65.doc, sp65/sp65.scn: Add new test case to
verify that obtaining a priority ceiling mutex when the calling
task's priority is the same as the priority ceiling is handled
correctly.
* sp65/init.c: Add semi-colon to end of rtems_semaphore_create call.
Change attributes to priority ceiling. Use directive_failed, not
assert. Configure a semaphore not a region.
* ChangeLog, Makefile.am, configure.ac: Add new test for some core
mutex cases.
* sp65/.cvsignore, sp65/Makefile.am, sp65/init.c, sp65/sp65.doc,
sp65/sp65.scn: New files.
