* sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c,
spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c,
spwkspace/init.c: Use rtems_test_assert() consistently instead of
system assert(). rtems_test_assert() is designed to integrate into
the RTEMS test suite infrastructure.
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c,
sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c,
sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86
at -Os and m68k at -Os. Fix typos.
* Makefile.am, configure.ac, sp62/init.c, sp64/init.c: Add new test and
adjust existing for alignment. New test ensures coverage begin and
end marker methods are exercised so they do not get considered
unexecuted.
* spcoverage/.cvsignore, spcoverage/Makefile.am, spcoverage/init.c,
spcoverage/spcoverage.doc, spcoverage/spcoverage.scn: New files.
* sp64/init.c, sp64/sp64.scn: Chris ensured that nothing is moved until
all memory is successfully allocated. This means the test can
validate the heap is unchanged on extend failure.
* Makefile.am, configure.ac, sp63/init.c: Add new test for exercising
when we are unable to allocate the memory needed for an object
extend. Make sure all is handled properly.
* sp64/.cvsignore, sp64/Makefile.am, sp64/init.c, sp64/sp64.doc,
sp64/sp64.scn: New files.
