path: root/testsuites/sptests/sp63 (follow)
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-081-7/+7
| | | | | | | | * sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c, spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c, spwkspace/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* Pass UINTPTR_MAX instead of 0xffffffff to _Heap_Allocate for 16bit compliance.Ralf Corsepius2009-10-301-1/+1
* Use PRIu32 to print uint32_t's.Ralf Corsepius2009-10-271-2/+2
* Fix _Heap_Resize_block args.Ralf Corsepius2009-10-261-4/+4
* Eliminate unused vars.Ralf Corsepius2009-10-241-2/+2
* 2009-08-25 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-08-261-3/+7
| | | | | * sp59/init.c, sp59/sp59.scn: Added status code assignment. Fixed typos. * sp63/init.c: Check return value of _Heap_Initialize().
* 2009-08-18 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-182-2/+8
| | | | | * sp63/init.c, sp63/sp63.scn: Add case for math on size requested overflowing on _Heap_Allocate_aligned.
* 2009-08-05 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-08-051-1/+50
| | | | | | | | * Makefile.am, configure.ac, sp63/init.c: Add new test for exercising when we are unable to allocate the memory needed for an object extend. Make sure all is handled properly. * sp64/.cvsignore, sp64/Makefile.am, sp64/init.c, sp64/sp64.doc, sp64/sp64.scn: New files.
* 2009-08-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-011-1/+1
| | | | * sp63/init.c: Correct test case two.
* 2009-08-01 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-012-8/+41
| | | | | * sp63/init.c, sp63/sp63.scn: Move into subroutines and add a second test case to exercise another odd branch not taken.
* 2009-07-31 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-015-0/+120
* Makefile.am, configure.ac, sp62/init.c: Add new test to ensure a particular path is taken through the _Heap_Resize_block code. * sp63/.cvsignore, sp63/Makefile.am, sp63/init.c, sp63/sp63.doc, sp63/sp63.scn: New files.
