* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+5 |
| | | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -1/+1 |
* | Use PRIdrtems_task_priority to print rtems_task_priority's. | Ralf Corsepius | 2009-10-26 | 1 | -1/+1 |
* | 2009-09-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-09-27 | 1 | -1/+1 |
| | | | | | * sp59/init.c, spintrcritical15/init.c, spintrcritical16/init.c: Correct minor issues uncovered on uC5282. | ||||
* | 2009-08-25 Sebastian Huber <Sebastian.Huber@embedded-brains.de> | Joel Sherrill | 2009-08-26 | 2 | -5/+5 |
| | | | | | * sp59/init.c, sp59/sp59.scn: Added status code assignment. Fixed typos. * sp63/init.c: Check return value of _Heap_Initialize(). | ||||
* | 2009-07-09 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-09 | 5 | -0/+192 |
* Makefile.am, configure.ac: Add sp59 to test path through _Thread_queue_First_priority where the task's priority was in the bottom 1/4 of the range. * sp59/.cvsignore, sp59/Makefile.am, sp59/init.c, sp59/sp59.doc, sp59/sp59.scn: New files. |
