Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
* sp58/init.c, sp58/sp58.scn: Account for case where left hand side
seconds field is less than.
* Makefile.am, configure.ac: Add test for timespec divide by zero.
* sp58/.cvsignore, sp58/Makefile.am, sp58/init.c, sp58/sp58.doc,
sp58/sp58.scn: New files.
