* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -12/+12 |
| | | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2009-10-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-10-02 | 1 | -2/+2 |
| | | | | | * sp54/init.c: Use rtems_build_id to make building Objects_Id RTEMS_USE_16_BIT_OBJECT clean. | ||||
* | 2009-07-08 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-08 | 1 | -1/+0 |
| | | | | | | | * sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded USE_TIMER_SERVER which was copied fomr other Makefile.am's. | ||||
* | 2009-07-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-03 | 2 | -0/+7 |
| | | | | * sp54/init.c, sp54/sp54.doc: Add test for Workspace zeroed. | ||||
* | 2009-07-03 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-03 | 2 | -2/+7 |
| | | | | * sp54/init.c, sp54/sp54.doc: Fix typos and comments. | ||||
* | 2009-06-12 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-06-12 | 1 | -1/+0 |
| | | | | * sp54/init.c: Fix spacing. | ||||
* | 2009-06-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-10 | 5 | -0/+140 |
* Makefile.am, configure.ac: Add new test. * sp54/.cvsignore, sp54/Makefile.am, sp54/init.c, sp54/sp54.doc, sp54/sp54.scn: New files. |
