* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-06-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-06-08 | 1 | -0/+25 |
* Makefile.am, configure.ac: Add sp52 and sp53 based upon bug report from Sergio Faustino <sergio.faustino@edisoft.pt> regarding moving the time of day forward not making server based timers fire. * sp52/.cvsignore, sp52/Makefile.am, sp52/init.c, sp52/sp52.doc, sp52/sp52.scn, sp53/.cvsignore, sp53/Makefile.am, sp53/sp53.doc, sp53/sp53.scn: New files. |
