Updates #3053.
This ensures that the configured semaphore maximum is not exceeded.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Use same structure as POSIX API for thread priority conversion to/from
SuperCore.
The holder field is enough to determine if a mutex is locked or not.
This leads also to better error status codes in case a
rtems_semaphore_release() is done for a mutex without having the
ownership.
* sp51/init.c, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am,
sp57/Makefile.am, spchain/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am: Remove unneeded
USE_TIMER_SERVER which was copied fomr other Makefile.am's.
* sp51/init.c, sp51/sp51.scn: Add more priority ceiling test cases.
PR 1415/cpukit
* Makefile.am, configure.ac: Add test for very simple priority ceiling
violation.
* sp51/.cvsignore, sp51/Makefile.am, sp51/init.c, sp51/sp51.doc,
sp51/sp51.scn: New files.
