* sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c,
sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c,
sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c,
sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c,
sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c,
sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c,
sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c,
spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp45/init.c: New file.
