path: root/testsuites/sptests/sp45/Makefile.am (unfollow)
2018-04-10testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns1-22/+0
This change is part of the testsuite Makefile.am reorganization. Update #3382
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-4/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+5
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-5/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+1
PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
2009-04-03Eliminate _exe_/.exe.Ralf Corsepius1-7/+7
2008-12-032008-12-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-0/+28
PR 1347/cpukit * Makefile.am, configure.ac, sp30/resume.c, sp30/task1.c, sp31/delay.c: Rework Timer Server to ensure that the context allows for blocking, allocating memory, and acquiring semaphores and mutexes. * sp45/.cvsignore, sp45/Makefile.am, sp45/sp45.doc, sp45/sp45.scn: New files.
