* | 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-10 | 1 | -0/+3 |
| | | | | | | | | | | | | | * sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c, sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h, spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c, spsize/size.c: Fix warnings. | ||||
* | Eliminate _exe_/.exe. | Ralf Corsepius | 2009-04-03 | 1 | -7/+7 |
* | 2008-08-05 Xudong Guan <xudong.guan@criticalsoftware.com> | Joel Sherrill | 2008-08-05 | 4 | -0/+191 |
PR 1212/cpukit * Makefile.am, configure.ac: Time slicing will not happen if the task mode is changed from a non-timeslicing mode to timeslicing mode if it is done by the executing thread (e.g. in its task body). This change includes sp44 to demonstrate the problem and verify the correction. * sp44/.cvsignore, sp44/Makefile.am, sp44/init.c, sp44/sp44.scn: New files. |
