* | testsuites/sptests/sp[4-7]*: Change license to BSD-2 | Joel Sherrill | 2022-04-05 | 1 | -3/+22 |
| | | | | Updates #3053. | ||||
* | rtems: Use RTEMS_WHO_AM_I for rtems_task_ident() | Sebastian Huber | 2021-11-18 | 1 | -1/+1 |
* | testsuites: Remove rtems_test_pause*() | Sebastian Huber | 2019-12-04 | 2 | -3/+0 |
| | | | | | | | | | | | | | The rtems_test_pause() and rtems_test_pause_and_screen_number() macros had different implementations depending on the RTEMS_TEST_NO_PAUSE define. This define was defined to 1 by default. The user was able to change this via the undocumented --disable-test-no-pause configure command line option. Pausing tests and waiting for user input contradicts the goal of having automated test runs. Remove this feature. Update #3818. | ||||
* | tests: Use rtems_task_exit() | Sebastian Huber | 2018-10-05 | 1 | -1/+1 |
| | | | | Update #3533. | ||||
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | sptests/sp42: Relax priority requirements | Sebastian Huber | 2016-06-23 | 1 | -3/+3 |
* | rtems: Fix no protocol mutex release | Sebastian Huber | 2016-06-06 | 2 | -42/+71 |
| | | | | | | | | | | | | | | | | The Classic binary semaphores without a locking protocol (RTEMS_BINARY_SEMAPHORE) could be released by everyone, e.g. in contrast to the POSIX mutexes (all variants) or the Classic binary semphores with priority inheritance or ceiling, there was no owner check in the release path. This behaviour was a bit unexpected and not documented. Add an owner check to the release path. Update sptests/sp42 accordingly. This change has nothing to do with the simple binary semaphores (RTEMS_SIMPLE_BINARY_SEMAPHORE) which have no owner at all. Update #2725 | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -13/+13 |
* | 2009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-07-30 | 4 | -10/+109 |
| | | | | | | | * sp42/Makefile.am, sp42/init.c, sp42/sp42.scn: Test was testing the wrong thing in a cpp macro. Added contents to screen file and add documentation file. * sp42/sp42.doc: New file. | ||||
* | 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-05-10 | 1 | -2/+10 |
| | | | | | | | | | | | | | * sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c, sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h, spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c, spsize/size.c: Fix warnings. | ||||
* | Eliminate _exe_/.exe. | Ralf Corsepius | 2009-04-03 | 1 | -7/+7 |
* | 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-14 | 1 | -0/+11 |
| | | | | | | | | | | | | * sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c, sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 1 | -1/+1 |
* | 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-29 | 1 | -1/+1 |
| | | | | | | | | | * Makefile.am, configure.ac, sp02/task1.c, sp24/resume.c, sp30/resume.c, sp41/init.c, sp42/init.c: Add new Object Services collection. This changed the name of a few previously public but undocumented services and added a some new services. * sp43/.cvsignore, sp43/Makefile.am, sp43/init.c, sp43/sp43.scn, sp43/system.h: New files. | ||||
* | 2008-01-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-24 | 1 | -2/+2 |
| | | | | | | * sp28/init.c, sp28/sp28.scn, sp29/init.c, sp29/sp29.scn, sp32/init.c, sp32/sp32.scn, sp33/init.c, sp33/sp33.scn, sp42/init.c: Fix end of test messages. | ||||
* | 2008-01-23 Jennifer Averett <jennifer.averett@OARcorp.com> | Jennifer Averett | 2008-01-23 | 1 | -0/+27 |
| | | | | * sp42/Makefile.am: New file. | ||||
* | 2008-01-23 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2008-01-23 | 3 | -0/+175 |
Add sp42 to exercise thread queue with knowledge of the implementation so we can exercise all of the normal paths possible. * Makefile.am, configure.ac: Add sp42. * sp42/.cvsignore, sp42/init.c, sp42/sp42.scn: New files. |
