path: root/testsuites/sptests/sp42 (unfollow)
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+1
PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
2011-02-22Add HAVE_CONFIG_H.Ralf Corsepius1-0/+4
2009-11-30Whitespace removal.Ralf Corsepius1-13/+13
2009-07-302009-07-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill4-10/+109
* sp42/Makefile.am, sp42/init.c, sp42/sp42.scn: Test was testing the wrong thing in a cpp macro. Added contents to screen file and add documentation file. * sp42/sp42.doc: New file.
2009-05-102009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+10
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c, sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h, spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c, spsize/size.c: Fix warnings.
2009-04-03Eliminate _exe_/.exe.Ralf Corsepius1-7/+7
2008-12-142008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-0/+11
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c, sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
2008-09-06Convert to "bool".Ralf Corsepius1-1/+1
2008-01-292008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-1/+1
* Makefile.am, configure.ac, sp02/task1.c, sp24/resume.c, sp30/resume.c, sp41/init.c, sp42/init.c: Add new Object Services collection. This changed the name of a few previously public but undocumented services and added a some new services. * sp43/.cvsignore, sp43/Makefile.am, sp43/init.c, sp43/sp43.scn, sp43/system.h: New files.
2008-01-242008-01-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+2
* sp28/init.c, sp28/sp28.scn, sp29/init.c, sp29/sp29.scn, sp32/init.c, sp32/sp32.scn, sp33/init.c, sp33/sp33.scn, sp42/init.c: Fix end of test messages.
2008-01-232008-01-23 Jennifer Averett <jennifer.averett@OARcorp.com>Jennifer Averett1-0/+27
* sp42/Makefile.am: New file.
2008-01-232008-01-23 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-0/+175
Add sp42 to exercise thread queue with knowledge of the implementation so we can exercise all of the normal paths possible. * Makefile.am, configure.ac: Add sp42. * sp42/.cvsignore, sp42/init.c, sp42/sp42.scn: New files.
