* sp42/Makefile.am, sp42/init.c, sp42/sp42.scn: Test was testing the
wrong thing in a cpp macro. Added contents to screen file and add
documentation file.
* sp42/sp42.doc: New file.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c,
sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c,
sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* Makefile.am, configure.ac, sp02/task1.c, sp24/resume.c,
sp30/resume.c, sp41/init.c, sp42/init.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* sp43/.cvsignore, sp43/Makefile.am, sp43/init.c, sp43/sp43.scn,
sp43/system.h: New files.
* sp28/init.c, sp28/sp28.scn, sp29/init.c, sp29/sp29.scn, sp32/init.c,
sp32/sp32.scn, sp33/init.c, sp33/sp33.scn, sp42/init.c: Fix end of
test messages.
Add sp42 to exercise thread queue with knowledge of the implementation
so we can exercise all of the normal paths possible.
* Makefile.am, configure.ac: Add sp42.
* sp42/.cvsignore, sp42/init.c, sp42/sp42.scn: New files.
