Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #2423.
application visible API.
* Makefile.am, configure.ac: Add new test to exercise odd case in
rtems_iterate_over_all_threads.
* sp41/.cvsignore, sp41/Makefile.am, sp41/init.c, sp41/sp41.doc,
sp41/sp41.scn: New files.
* Makefile.am, configure.ac: Add new infrastructure which is more
reliable about generating cases which hit interrupt critical
sections. Remove sp41 since it used its own mechanism.
* spintrcritical01/.cvsignore, spintrcritical01/Makefile.am,
spintrcritical01/init.c, spintrcritical01/spintrcritical01.doc,
spintrcritical01/spintrcritical01.scn, spintrcritical02/.cvsignore,
spintrcritical02/Makefile.am, spintrcritical02/spintrcritical02.doc,
spintrcritical02/spintrcritical02.scn, spintrcritical03/.cvsignore,
spintrcritical03/Makefile.am, spintrcritical03/spintrcritical03.doc,
spintrcritical03/spintrcritical03.scn, spintrcritical04/.cvsignore,
spintrcritical04/Makefile.am, spintrcritical04/spintrcritical04.doc,
spintrcritical04/spintrcritical04.scn, spintrcritical05/.cvsignore,
spintrcritical05/Makefile.am, spintrcritical05/spintrcritical05.doc,
spintrcritical05/spintrcritical05.scn: New files.
* sp41/.cvsignore, sp41/Makefile.am, sp41/init.c, sp41/sp41.scn,
sp41/system.h: Removed.
* sp41/init.c: Remove incorrect comment.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp09/screen01.c, sp09/screen12.c, sp25/system.h, sp25/task1.c,
sp28/init.c, sp39/init.c, sp41/init.c, spfatal01/testcase.h,
spfatal08/testcase.h: Change size_t to ssize_t on all Heap, Workspace
and Region calls. On 16-bit architectures, size_t can be 16-bits
which would limit sizes to 64K. Also address constants which
overflowed on 16-bit integer targets.
* sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c,
sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c,
sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c,
sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c,
sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c,
sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c,
spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change
TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX
tests. Add a clock_settime case for < 1988.
* Makefile.am, configure.ac, sp02/task1.c, sp24/resume.c,
sp30/resume.c, sp41/init.c, sp42/init.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* sp43/.cvsignore, sp43/Makefile.am, sp43/init.c, sp43/sp43.scn,
sp43/system.h: New files.
* sp39/init.c: Add case for long timeout on blocking operation.
* Makefile.am, configure.ac: Add new test to exercise thread
queue blokcing synchronization. sp39 and sp41 are very similar.
sp41/system.h: New files.
