path: root/testsuites/sptests/sp40 (follow)
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* score: Use ISR lock for IO driver registrationSebastian Huber2016-03-141-0/+2
| | | | | | Create implementation header file. Update #2555.
* rtems: Add rtems_interrupt_local_disable|enable()Sebastian Huber2015-06-221-4/+2
| | | | | | | | Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to emphasize that interrupts are only disabled on the current processor. Do not define the rtems_interrupt_disable|enable|flash() macros and functions on SMP configurations since they don't ensure system wide mutual exclusion.
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-251-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* PR766: Delete __RTEMS_VIOLATE_KERNEL_VISIBILITY__Sebastian Huber2013-08-081-2/+0
* sptests - Eliminate missing prototype warningsJoel Sherrill2012-05-311-1/+4
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-9/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-09-02 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-021-16/+26
| | | | * sp40/init.c: Avoid unsupported test cases.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2009-10-09 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Joel Sherrill2009-10-093-17/+114
| | | | | | | * sp40/init.c, sp40/sp40.doc, sp40/sp40.scn: New test cases. * spintrcritical09/init.c, spintrcritical10/init.c, spintrcritical11/init.c: Fixed potentially infinite loops.
* 2009-07-24 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-254-3/+41
| | | | | | * Makefile.am, configure.ac, sp40/Makefile.am, sp40/init.c, sp40/sp40.scn: Now verified to hit coverage cases. * sp40/sp40.doc: New file.
* 2009-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-07-254-52/+59
| | | | | | * sp40/Makefile.am, sp40/init.c, sp40/sp40.scn: Attempt to write test to catch two remaining uncovered cases in rtems_io_register_driver. * sp40/system.h: Removed.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-011-1/+1
| | | | | | | | | | | | | * sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c, sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c, sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c, sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c, sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c, sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c, sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c, spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-312-0/+5
| | | | | | | | * sp09/screen01.c, sp09/sp09.scn: Add more bad thread Id cases. * sp40/init.c, sp40/sp40.scn: Add message to say test is TBD. * sp41/sp41.scn: Now has content. * sp43/init.c, sp43/sp43.scn: Enhanced to increase coverage of Object Services recently added to API.
* 2008-01-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-085-0/+105
* Makefile.am, configure.ac: Add sp40 to test some cases of dynamic driver registration. * sp40/.cvsignore, sp40/Makefile.am, sp40/init.c, sp40/sp40.scn, sp40/system.h: New files.
