Update #3533.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Avoid direct access to thread internal data fields.
for details.
PR 1589/build
sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am,
sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am,
sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am,
sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am,
sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am,
sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am,
sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am,
sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am,
sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am,
sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am,
sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am,
sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am,
sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am,
sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am,
sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am,
sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am,
sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am,
spcbssched01/Makefile.am, spcbssched02/Makefile.am,
spcbssched03/Makefile.am, spchain/Makefile.am,
spclockget/Makefile.am, spcoverage/Makefile.am,
spedfsched01/Makefile.am, spedfsched02/Makefile.am,
spedfsched03/Makefile.am, sperror01/Makefile.am,
sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am,
spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am,
spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am,
spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am,
spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am,
spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am,
spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am,
spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am,
spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am,
spintrcritical01/Makefile.am, spintrcritical02/Makefile.am,
spintrcritical03/Makefile.am, spintrcritical04/Makefile.am,
spintrcritical05/Makefile.am, spintrcritical06/Makefile.am,
spintrcritical07/Makefile.am, spintrcritical08/Makefile.am,
spintrcritical09/Makefile.am, spintrcritical10/Makefile.am,
spintrcritical11/Makefile.am, spintrcritical12/Makefile.am,
spintrcritical13/Makefile.am, spintrcritical14/Makefile.am,
spintrcritical15/Makefile.am, spintrcritical16/Makefile.am,
spintrcritical17/Makefile.am, spmkdir/Makefile.am,
spmountmgr01/Makefile.am, spnotepad01/Makefile.am,
spnsext01/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spprivenv01/Makefile.am,
sprbtree01/Makefile.am, spsimplesched01/Makefile.am,
spsimplesched02/Makefile.am, spsimplesched03/Makefile.am,
spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am,
spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete
optional manager capability.
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* sp35/priinv.c, sp35/priinv.c: Declare unions volatile to
workaround the H8300 gcc bug.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp34/sp34.scn, sp35/sp35.scn: Convert to UNIX CR/LF style.
* sp34/changepri.c, sp35/priinv.c: Convert the Objects_Name type from a
* sp07/task1.c, sp34/changepri.c, sp35/priinv.c: Add rtems_task_self()
directive instead of violating RTEMS internals.
* sp20/task1.c, sp34/changepri.c, sp35/priinv.c: Build when using
buffered test IO.
* sp13/system.h, sp34/changepri.c, sp35/priinv.c: Avoid using
CONFIGURE_MEMORY_OVERHEAD and try to really account for the memory
properly.
sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am,
sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am,
spsize/size.c: Add optional managers to Makefiles. Clean up test
cases so last output line follows END OF pattern. Make sure test case
all run. All tests appeared ok on sis.
* sp34/changepri.c, sp35/priinv.c: Change all obsoleted
CONFIGURE_TEST_NEEDS_XXX configuration constants to
CONFIGURE_APPLICATION_NEEDS_XXX.
PR 1222/cpukit
* Makefile.am, configure.ac: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* sp34/.cvsignore, sp34/Makefile.am, sp34/changepri.c, sp34/sp34.doc,
sp34/sp34.scn, sp35/.cvsignore, sp35/Makefile.am, sp35/priinv.c,
sp35/sp35.doc, sp35/sp35.scn: New files.
