Encapsulate the current_priority and real_priority fields of
the thread control block with a Thread_Priority_node struct.
Propagate modifications throughout the tree where the two
fields are directly accessed.
Updates #3359.
* sp35/priinv.c, sp35/priinv.c: Declare unions volatile to
workaround the H8300 gcc bug.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp34/changepri.c, sp35/priinv.c: Convert the Objects_Name type from a
* sp07/task1.c, sp34/changepri.c, sp35/priinv.c: Add rtems_task_self()
directive instead of violating RTEMS internals.
* sp20/task1.c, sp34/changepri.c, sp35/priinv.c: Build when using
buffered test IO.
* sp13/system.h, sp34/changepri.c, sp35/priinv.c: Avoid using
CONFIGURE_MEMORY_OVERHEAD and try to really account for the memory
properly.
* sp34/changepri.c, sp35/priinv.c: Change all obsoleted
CONFIGURE_TEST_NEEDS_XXX configuration constants to
CONFIGURE_APPLICATION_NEEDS_XXX.
PR 1222/cpukit
* Makefile.am, configure.ac: Enhance so that when the prioirity of a
thread that is blocked on a priority based thread queue is changed,
that its placement in the queue is reevaluated based upon the new
priority. This enhancement includes modifications to the SuperCore as
well as new test cases.
* sp34/.cvsignore, sp34/Makefile.am, sp34/changepri.c, sp34/sp34.doc,
sp34/sp34.scn, sp35/.cvsignore, sp35/Makefile.am, sp35/priinv.c,
sp35/sp35.doc, sp35/sp35.scn: New files.
