for details.
PR 1589/build
sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am,
sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am,
sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am,
sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am,
sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am,
sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am,
sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am,
sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am,
sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am,
sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am,
sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am,
sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am,
sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am,
sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am,
sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am,
sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am,
sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am,
sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am,
sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am,
spcbssched01/Makefile.am, spcbssched02/Makefile.am,
spcbssched03/Makefile.am, spchain/Makefile.am,
spclockget/Makefile.am, spcoverage/Makefile.am,
spedfsched01/Makefile.am, spedfsched02/Makefile.am,
spedfsched03/Makefile.am, sperror01/Makefile.am,
sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am,
spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am,
spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am,
spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am,
spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am,
spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am,
spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am,
spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am,
spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am,
spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am,
spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am,
spintrcritical01/Makefile.am, spintrcritical02/Makefile.am,
spintrcritical03/Makefile.am, spintrcritical04/Makefile.am,
spintrcritical05/Makefile.am, spintrcritical06/Makefile.am,
spintrcritical07/Makefile.am, spintrcritical08/Makefile.am,
spintrcritical09/Makefile.am, spintrcritical10/Makefile.am,
spintrcritical11/Makefile.am, spintrcritical12/Makefile.am,
spintrcritical13/Makefile.am, spintrcritical14/Makefile.am,
spintrcritical15/Makefile.am, spintrcritical16/Makefile.am,
spintrcritical17/Makefile.am, spmkdir/Makefile.am,
spmountmgr01/Makefile.am, spnotepad01/Makefile.am,
spnsext01/Makefile.am, spobjgetnext/Makefile.am,
spprintk/Makefile.am, spprivenv01/Makefile.am,
sprbtree01/Makefile.am, spsimplesched01/Makefile.am,
spsimplesched02/Makefile.am, spsimplesched03/Makefile.am,
spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am,
spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete
optional manager capability.
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c,
sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c,
sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c,
sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c,
sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c,
sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c,
sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c,
spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c:
Do not line length exceed 80 columns.
* sp09/screen02.c, sp09/screen13.c, sp09/sp09.scn, sp29/init.c,
sp30/sp30.scn, sp32/init.c, spclockget/init.c: Avoid use of
deprecated rtems_clock_get() except in spclockget().
Misc. changes related to rtems_intervals.
* sp29/init.c: Fixed return value evaluation.
* sp59/init.c: Added status code assignment. Fixed typos.
* sp59/init.c, sp59/sp59.scn: Added status code assignment. Fixed typos.
* sp63/init.c: Check return value of _Heap_Initialize().
* sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c,
sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c,
sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c,
sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c,
sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c,
sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c,
sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c,
sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c,
spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* sp29/init.c: Simple binary semaphores can not be inherit priority.
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c,
sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c,
sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests
successfully with maxixum number of priorities as 16 instead of 256.
This was done by temporarily modifying the score priority.h maximum.
This allowed testing of all API code to ensure that it worked
properly with a reduced number of priorities. Most modifications were
to switch from hard-coded maximum to using the API provided methods
to determine maximum number of priority levels.
* sp28/init.c, sp28/sp28.scn, sp29/init.c, sp29/sp29.scn, sp32/init.c,
sp32/sp32.scn, sp33/init.c, sp33/sp33.scn, sp42/init.c: Fix end of
test messages.
* sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* sp02/Makefile.am: Ditto.
* sp03/Makefile.am: Ditto.
* sp04/Makefile.am: Ditto.
* sp05/Makefile.am: Ditto.
* sp06/Makefile.am: Ditto.
* sp07/Makefile.am: Ditto.
* sp08/Makefile.am: Ditto.
* sp09/Makefile.am: Ditto.
* sp11/Makefile.am: Ditto.
* sp12/Makefile.am: Ditto.
* sp13/Makefile.am: Ditto.
* sp14/Makefile.am: Ditto.
* sp15/Makefile.am: Ditto.
* sp16/Makefile.am: Ditto.
* sp17/Makefile.am: Ditto.
* sp19/Makefile.am: Ditto.
* sp20/Makefile.am: Ditto.
* sp21/Makefile.am: Ditto.
* sp22/Makefile.am: Ditto.
* sp23/Makefile.am: Ditto.
* sp24/Makefile.am: Ditto.
* sp25/Makefile.am: Ditto.
* sp26/Makefile.am: Ditto.
* sp27/Makefile.am: Ditto.
* sp28/Makefile.am: Ditto.
* sp29/Makefile.am: Ditto.
* sp30/Makefile.am: Ditto.
* sp31/Makefile.am: Ditto.
* sp32/Makefile.am: Ditto.
* spfatal/Makefile.am: Ditto.
* spsize/Makefile.am: Ditto.
* sp01/Makefile.am: Remove all-local: $(ARCH).
* sp02/Makefile.am: Remove all-local: $(ARCH).
* sp03/Makefile.am: Remove all-local: $(ARCH).
* sp04/Makefile.am: Remove all-local: $(ARCH).
* sp05/Makefile.am: Remove all-local: $(ARCH).
* sp06/Makefile.am: Remove all-local: $(ARCH).
* sp07/Makefile.am: Remove all-local: $(ARCH).
* sp08/Makefile.am: Remove all-local: $(ARCH).
* sp09/Makefile.am: Remove all-local: $(ARCH).
* sp11/Makefile.am: Remove all-local: $(ARCH).
* sp12/Makefile.am: Remove all-local: $(ARCH).
* sp13/Makefile.am: Remove all-local: $(ARCH).
* sp14/Makefile.am: Remove all-local: $(ARCH).
* sp15/Makefile.am: Remove all-local: $(ARCH).
* sp16/Makefile.am: Remove all-local: $(ARCH).
* sp17/Makefile.am: Remove all-local: $(ARCH).
* sp19/Makefile.am: Remove all-local: $(ARCH).
* sp20/Makefile.am: Remove all-local: $(ARCH).
* sp21/Makefile.am: Remove all-local: $(ARCH).
* sp22/Makefile.am: Remove all-local: $(ARCH).
* sp23/Makefile.am: Remove all-local: $(ARCH).
* sp24/Makefile.am: Remove all-local: $(ARCH).
* sp25/Makefile.am: Remove all-local: $(ARCH).
* sp26/Makefile.am: Remove all-local: $(ARCH).
* sp27/Makefile.am: Remove all-local: $(ARCH).
* sp28/Makefile.am: Remove all-local: $(ARCH).
* sp29/Makefile.am: Remove all-local: $(ARCH).
* sp30/Makefile.am: Remove all-local: $(ARCH).
* sp31/Makefile.am: Remove all-local: $(ARCH).
* sp32/Makefile.am: Remove all-local: $(ARCH).
* spfatal/Makefile.am: Remove all-local: $(ARCH).
* spsize/Makefile.am: Remove all-local: $(ARCH).
sp01/Makefile.am: Reflect having moved automake.
sp02/Makefile.am: Reflect having moved automake.
sp03/Makefile.am: Reflect having moved automake.
sp04/Makefile.am: Reflect having moved automake.
sp05/Makefile.am: Reflect having moved automake.
sp06/Makefile.am: Reflect having moved automake.
sp07/Makefile.am: Reflect having moved automake.
sp08/Makefile.am: Reflect having moved automake.
sp09/Makefile.am: Reflect having moved automake.
sp11/Makefile.am: Reflect having moved automake.
sp12/Makefile.am: Reflect having moved automake.
sp13/Makefile.am: Reflect having moved automake.
sp14/Makefile.am: Reflect having moved automake.
sp15/Makefile.am: Reflect having moved automake.
sp16/Makefile.am: Reflect having moved automake.
sp17/Makefile.am: Reflect having moved automake.
sp19/Makefile.am: Reflect having moved automake.
sp20/Makefile.am: Reflect having moved automake.
sp21/Makefile.am: Reflect having moved automake.
sp22/Makefile.am: Reflect having moved automake.
sp23/Makefile.am: Reflect having moved automake.
sp24/Makefile.am: Reflect having moved automake.
sp25/Makefile.am: Reflect having moved automake.
sp26/Makefile.am: Reflect having moved automake.
sp27/Makefile.am: Reflect having moved automake.
sp28/Makefile.am: Reflect having moved automake.
sp29/Makefile.am: Reflect having moved automake.
sp30/Makefile.am: Reflect having moved automake.
sp31/Makefile.am: Reflect having moved automake.
sp32/Makefile.am: Reflect having moved automake.
spfatal/Makefile.am: Reflect having moved automake.
spsize/Makefile.am: Reflect having moved automake.
* sp27/init.c, sp29/init.c, spsize/size.c: Removed warnings.
* sp01/Makefile.am: Use $(OBJEXT) instead of .o.
* sp02/Makefile.am: Use $(OBJEXT) instead of .o.
* sp03/Makefile.am: Use $(OBJEXT) instead of .o.
* sp04/Makefile.am: Use $(OBJEXT) instead of .o.
* sp05/Makefile.am: Use $(OBJEXT) instead of .o.
* sp06/Makefile.am: Use $(OBJEXT) instead of .o.
* sp07/Makefile.am: Use $(OBJEXT) instead of .o.
* sp08/Makefile.am: Use $(OBJEXT) instead of .o.
* sp09/Makefile.am: Use $(OBJEXT) instead of .o.
* sp11/Makefile.am: Use $(OBJEXT) instead of .o.
* sp12/Makefile.am: Use $(OBJEXT) instead of .o.
* sp13/Makefile.am: Use $(OBJEXT) instead of .o.
* sp14/Makefile.am: Use $(OBJEXT) instead of .o.
* sp15/Makefile.am: Use $(OBJEXT) instead of .o.
* sp16/Makefile.am: Use $(OBJEXT) instead of .o.
* sp17/Makefile.am: Use $(OBJEXT) instead of .o.
* sp19/Makefile.am: Use $(OBJEXT) instead of .o.
* sp20/Makefile.am: Use $(OBJEXT) instead of .o.
* sp21/Makefile.am: Use $(OBJEXT) instead of .o.
* sp22/Makefile.am: Use $(OBJEXT) instead of .o.
* sp23/Makefile.am: Use $(OBJEXT) instead of .o.
* sp24/Makefile.am: Use $(OBJEXT) instead of .o.
* sp25/Makefile.am: Use $(OBJEXT) instead of .o.
* sp26/Makefile.am: Use $(OBJEXT) instead of .o.
* sp27/Makefile.am: Use $(OBJEXT) instead of .o.
* sp28/Makefile.am: Use $(OBJEXT) instead of .o.
* sp29/Makefile.am: Use $(OBJEXT) instead of .o.
* sp30/Makefile.am: Use $(OBJEXT) instead of .o.
* sp31/Makefile.am: Use $(OBJEXT) instead of .o.
* spfatal/Makefile.am: Use $(OBJEXT) instead of .o.
* spsize/Makefile.am: Use $(OBJEXT) instead of .o.
* sp29/init.c: Corrected definitions for task stack usage.
* sp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp30/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp31/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
and his EPICS porting effort.
