path: root/testsuites/sptests/sp25 (follow)
* updated copyright to 1998Joel Sherrill1998-02-174-4/+4
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-084-8/+8
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-224-20/+20
* corrected printf specifications and added casts as necessary to eliminateJoel Sherrill1997-04-071-1/+2
| | | | warnings.
* corrected printf format to avoid warningJoel Sherrill1997-04-021-1/+1
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-1/+1
| | | | to avoid conflict with the standard POSIX routine pause(2).
* Modified UNIX simulator port so all references to native unixJoel Sherrill1995-09-271-1/+1
| | | | | stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files.
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-10/+30
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-231-1/+1
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* Changed to reflect adding object class to idJoel Sherrill1995-08-182-2/+2
| | | | Added "0x" to printf of id
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-115-0/+403
