2019-12-04 | testsuites: Remove rtems_test_pause*() | Sebastian Huber | 1 | -1/+0 | |
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros had different implementations depending on the RTEMS_TEST_NO_PAUSE define. This define was defined to 1 by default. The user was able to change this via the undocumented --disable-test-no-pause configure command line option. Pausing tests and waiting for user input contradicts the goal of having automated test runs. Remove this feature. Update #3818. | |||||
2009-08-10 | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 1 | -7/+7 | |
* sp01/sp01.scn, sp01/task1.c, sp03/task1.c, sp03/task2.c, sp04/task1.c, sp04/tswitch.c, sp09/screen02.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.scn, sp11/sp11.scn, sp11/task1.c, sp11/task2.c, sp19/fptask.c, sp19/sp19.scn, sp19/task1.c, sp22/prtime.c, sp22/sp22.scn, sp22/task1.c, sp24/sp24.scn, sp24/task1.c, sp30/task1.c, sp31/prtime.c, sp31/sp31.scn, sp31/task1.c, spwatchdog/prtime.c, spwatchdog/spwatchdog.scn, spwatchdog/task1.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..). | |||||
2002-11-14 | 2002-11-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -2/+2 | |
* sp02/sp02.scn, sp15/sp15.scn, sp16/sp16.scn, sp20/sp20.scn, sp22/sp22.scn, sp23/sp23.scn, sp25/sp25.scn, sp31/sp31.scn: Per PR239 update the IDs in the screens. | |||||
2000-01-05 | Changed screen to reflect change in object class numbers with ITRON | Joel Sherrill | 1 | -2/+2 | |
addition. | |||||
1995-09-27 | Modified UNIX simulator port so all references to native unix | Joel Sherrill | 1 | -2/+2 | |
stuff is in the executive source proper in the file cpu.c. This should help avoid conflicts between RTEMS POSIX files and UNIX files. | |||||
1995-08-23 | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1 | -2/+2 | |
Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | |||||
1995-08-18 | Changed to reflect adding object class to id | Joel Sherrill | 1 | -2/+2 | |
