path: root/testsuites/sptests/sp21/system.h (follow)
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-281-0/+1
| | | | | * Side-effect of PR132. * sp21/system.h: Now must explicitly request NULL driver.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-4/+4
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+20
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-111-0/+30
