* | 2011-05-13 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-05-13 | 1 | -0/+1 |
| | | | | * sp21/init.c, sp21/sp21.doc sp21/sp21.scn: New test cases. | ||||
* | 2010-07-06 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-07-06 | 1 | -2/+3 |
| | | | | | * sp21/init.c, sp21/sp21.scn: Tidy up with one last case to get 100% coverage of rtems_io_lookup_name(). | ||||
* | 2010-07-06 Joel Sherrill <joel.sherrilL@OARcorp.com> | Joel Sherrill | 2010-07-06 | 1 | -22/+24 |
| | | | | | | * sp21/Makefile.am, sp21/init.c, sp21/sp21.scn: Add rtems_io_lookup_name() and simplify test. * sp21/system.h, sp21/task1.c: Removed. | ||||
* | 2007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-29 | 1 | -0/+9 |
| | | | | | * sp21/sp21.scn, sp21/task1.c: rtems_io_register_driver and rtems_io_unregister_driver did not have any test code. | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+19 |
