* sp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp30/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp31/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* sp20/system.h: Account for extra task stacks properly.
* sp20/sp20.scn: Corrected to reflect new addition.
* sp20/system.h: Removed comment reflecting history.
* sp20/getall.c, sp20/init.c, sp20/system.h, sp20/task1.c:
Added new task to test sequence of altering a period's length
while it is still active.
addition.
more accurate.
like signal dispatching.
