* | score: Change TOD_LATEST_YEAR to 2099 | Sebastian Huber | 2021-09-06 | 1 | -38/+5 |
| | | | | | | | | This simplifies the implementation a bit. Declare _TOD_Days_to_date[] in <rtems/score/todimpl.h>. Make _TOD_Days_per_month[] and _TOD_Days_since_last_leap_year[] static. Update #4338. | ||||
* | rtems: Constify rtems_task_wake_when() | Sebastian Huber | 2021-05-12 | 1 | -2/+2 |
| | | | | | | | | | | | | | | | | Add a parameter to _TOD_Validate() to disable the validation of the ticks member. There are two reasons for this change. Firstly, in rtems_task_wake_when() was a double check for time_buffer == NULL (one in rtems_task_wake_when() and one in _TOD_Validate()). Secondly, the ticks member is ignored by rtems_task_wake_when(). This was done with a write of zero to the ticks member and thus a modification of the user-provided structure. Now the structure is no longer modified. Using a mask parameter is quite efficient. You just have to load an immediate value and there are no additional branches in _TOD_Validate(). Close #4406. | ||||
* | _TOD_Validate(): Fix incorrect return code | Frank Kühndel | 2021-05-12 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | This patch fixes bug #4403. Directives * rtems_timer_fire_when() * rtems_timer_server_fire_when() * rtems_task_wake_when() are documented to return RTEMS_INVALID_ADDRESS when their time-of-day argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix the issue this patch changes _TOD_Validate() to return a status code instead of just true/false. Close #4403 | ||||
* | clock:_TOD_To_seconds(): Fix year 2514 overflow | Frank Kühndel | 2021-04-21 | 1 | -10/+18 |
| | | | | | | | | | | | | | | | | | | | | | | | This patch fixes issue #4338 by changing _TOD_Validate() to only accept years till 2105. This requires another patch to change the documentation of rtems_clock_set() and other affected API functions (indicating the end date is 2105 not 2514). I tried to support till year 2514 but it turned out that this needs changing the Timer Manager too. That in turn would mean to change _TOD_Seconds_since_epoch( void ) from 32 to 64 bit. Sebastian pointed out that a naive extension leads to trouble with 32 bit processors. He deemed a safe re-implementation too costly performance wise considering that year 2106 is far away and current binaries using RTEMS Classic API are unlikely to be in use by 2106. The constant TOD_SECONDS_AT_2100_03_01_00_00 in cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by 1 hour. When setting the date 2100-Feb-28 23:59:59 and then reading the date again you will find yourself in 2100-Feb-27. Update #4338 | ||||
* | rtems: Add <rtems/rtems/clockimpl.h> | Sebastian Huber | 2020-12-02 | 1 | -0/+1 |
* | testsuite/sptests: Merged nested Makefile.am files into one Makefile.am | Chris Johns | 2018-04-10 | 1 | -22/+0 |
| | | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382 | ||||
* | tests: Use simple console driver | Sebastian Huber | 2017-11-06 | 1 | -1/+1 |
| | | | | | Update #3170. Update #3199. | ||||
* | tests: Remove TEST_INIT | Sebastian Huber | 2017-10-28 | 1 | -2/+0 |
| | | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199. | ||||
* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | score: Delete obsolete CPU_TIMESTAMP_* defines | Sebastian Huber | 2016-01-25 | 1 | -7/+2 |
| | | | | Update #2271. | ||||
* | rtems: Fix sp2038 test. | Chris Johns | 2014-05-22 | 1 | -0/+37 |
| | | | | | | | | Avoid using newlib's gmtime_r call which fails with a max signed int. Add an RTEMS specific version for 1/1/1988 to 31/12/2100. Update sp2038 to test every day from 1/1/1988 to 31/12/2100. Only days need be tested as the code splits the seconds based on days. | ||||
* | tests/sptests: Use <rtems/test.h> | Sebastian Huber | 2014-03-25 | 1 | -2/+6 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | sptest: sp2038: Add a test for leap year | Chirayu Desai | 2013-12-05 | 1 | -0/+32 |
| | | | | Bug test case for PR 1422 | ||||
* | sptests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-31 | 1 | -0/+3 |
* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 3 | -9/+0 |
* | Revert: Remove CVS Ids | Joel Sherrill | 2012-05-07 | 1 | -0/+5 |
| | | | | | See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details. | ||||
* | Remove CVS-Ids. | Ralf Corsépius | 2012-05-04 | 1 | -5/+0 |
* | Remove all .cvsignore files. | Joel Sherrill | 2012-02-01 | 1 | -2/+0 |
* | 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-08 | 1 | -3/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability. | ||||
* | 2011-10-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-10-06 | 1 | -0/+2 |
| | | | | * sp2038/.cvsignore: New file. | ||||
* | 2011-09-29 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-29 | 1 | -7/+154 |
| | | | | * sp2038/init.c: More test cases. | ||||
* | 2011-09-28 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-28 | 4 | -0/+180 |
* sp2038/Makefile.am, sp2038/init.c, sp2038/sp2038.doc, sp2038/sp2038.scn: New files. * Makefile.am, configure.ac: Reflect changes above. |
