path: root/testsuites/sptests/sp20/init.c (follow)
* SPARC port passes all testsJoel Sherrill1995-10-301-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+1
* Initial revisionJoel Sherrill1995-05-111-0/+71
