path: root/testsuites/sptests/sp19/task1.c (follow)
* testsuites/sptests/sp1*: Change license to BSD-2Joel Sherrill2022-04-051-3/+22
| | | | Updates #3053.
* rtems: Use RTEMS_WHO_AM_I for rtems_task_ident()Sebastian Huber2021-11-181-1/+1
* 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-241-13/+7
| | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* Add missing PRI*32's.Ralf Corsepius2009-10-261-1/+1
* 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-121-2/+2
| | | | | | | | | | | | | | | * sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c, sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c, sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c, sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c, sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c, spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second().
* 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-101-3/+3
| | | | | | | | | | | | * sp01/sp01.scn, sp01/task1.c, sp03/task1.c, sp03/task2.c, sp04/task1.c, sp04/tswitch.c, sp09/screen02.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.scn, sp11/sp11.scn, sp11/task1.c, sp11/task2.c, sp19/fptask.c, sp19/sp19.scn, sp19/task1.c, sp22/prtime.c, sp22/sp22.scn, sp22/task1.c, sp24/sp24.scn, sp24/task1.c, sp30/task1.c, sp31/prtime.c, sp31/sp31.scn, sp31/task1.c, spwatchdog/prtime.c, spwatchdog/spwatchdog.scn, spwatchdog/task1.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-301-1/+1
| | | | | | | | | | | | | | * sp02/task1.c, sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp05/task1.c, sp06/task1.c, sp09/screen01.c, sp09/screen07.c, sp09/screen12.c, sp09/system.h, sp09/task3.c, sp11/task1.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/system.h, sp15/system.h, sp16/system.h, sp17/system.h, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/system.h, sp19/task1.c, sp20/init.c, sp20/system.h, sp20/task1.c, sp23/system.h, sp24/init.c, sp25/system.h, sp30/init.c, spfatal/fatal.c, spfatal/puterr.c, spfatal/system.h, spsize/size.c: Convert to using c99 fixed size types.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed.
* Initial revisionJoel Sherrill1995-05-111-0/+59
