* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-12-08 | 1 | -8/+8 |
| | | | | | | | | * sp18/init.c, sp31/task1.c, sp43/init.c, sp63/init.c, sp64/init.c, spfatal10/testcase.h, spfatal11/testcase.h, spobjgetnext/init.c, spwkspace/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure. | ||||
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -2/+2 |
* | Eliminate unused vars. | Ralf Corsepius | 2009-10-24 | 1 | -1/+0 |
* | 2009-07-29 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-07-30 | 5 | -0/+167 |
* Makefile.am, configure.ac: Add new test to exercise as many cases as possible of not being able to allocate memory from the workspace during thread creation. * sp18/.cvsignore, sp18/Makefile.am, sp18/init.c, sp18/sp18.doc, sp18/sp18.scn: New files. |
