path: root/testsuites/sptests/sp17 (follow)
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-086-12/+12
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-226-30/+30
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-2/+2
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+33
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-117-0/+270
