* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c,
sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c,
sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h,
sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c,
sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c,
sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c,
spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h,
spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c,
spsize/size.c: Fix warnings.
* sp15/system.h, sp19/system.h: Array of task names should be of type
rtems_name not rtems_id. Similarly array of task ids should be
rtems_id not rtems_name.
* sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c,
sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c,
sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c,
sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c,
sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c,
sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c,
sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c,
spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change
TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX
tests. Add a clock_settime case for < 1988.
sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am,
sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am,
sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am,
spsize/size.c: Add optional managers to Makefiles. Clean up test
cases so last output line follows END OF pattern. Make sure test case
all run. All tests appeared ok on sis.
* sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* sp02/task1.c, sp04/system.h, sp04/task1.c, sp04/tswitch.c,
sp05/task1.c, sp06/task1.c, sp09/screen01.c, sp09/screen07.c,
sp09/screen12.c, sp09/system.h, sp09/task3.c, sp11/task1.c,
sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp13/task1.c,
sp13/task2.c, sp13/task3.c, sp14/system.h, sp15/system.h,
sp16/system.h, sp17/system.h, sp19/first.c, sp19/fptask.c,
sp19/inttest.h, sp19/system.h, sp19/task1.c, sp20/init.c,
sp20/system.h, sp20/task1.c, sp23/system.h, sp24/init.c,
sp25/system.h, sp30/init.c, spfatal/fatal.c, spfatal/puterr.c,
spfatal/system.h, spsize/size.c: Convert to using c99 fixed size
types.
* sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* sp02/Makefile.am: Ditto.
* sp03/Makefile.am: Ditto.
* sp04/Makefile.am: Ditto.
* sp05/Makefile.am: Ditto.
* sp06/Makefile.am: Ditto.
* sp07/Makefile.am: Ditto.
* sp08/Makefile.am: Ditto.
* sp09/Makefile.am: Ditto.
* sp11/Makefile.am: Ditto.
* sp12/Makefile.am: Ditto.
* sp13/Makefile.am: Ditto.
* sp14/Makefile.am: Ditto.
* sp15/Makefile.am: Ditto.
* sp16/Makefile.am: Ditto.
* sp17/Makefile.am: Ditto.
* sp19/Makefile.am: Ditto.
* sp20/Makefile.am: Ditto.
* sp21/Makefile.am: Ditto.
* sp22/Makefile.am: Ditto.
* sp23/Makefile.am: Ditto.
* sp24/Makefile.am: Ditto.
* sp25/Makefile.am: Ditto.
* sp26/Makefile.am: Ditto.
* sp27/Makefile.am: Ditto.
* sp28/Makefile.am: Ditto.
* sp29/Makefile.am: Ditto.
* sp30/Makefile.am: Ditto.
* sp31/Makefile.am: Ditto.
* sp32/Makefile.am: Ditto.
* spfatal/Makefile.am: Ditto.
* spsize/Makefile.am: Ditto.
* sp01/Makefile.am: Remove all-local: $(ARCH).
* sp02/Makefile.am: Remove all-local: $(ARCH).
* sp03/Makefile.am: Remove all-local: $(ARCH).
* sp04/Makefile.am: Remove all-local: $(ARCH).
* sp05/Makefile.am: Remove all-local: $(ARCH).
* sp06/Makefile.am: Remove all-local: $(ARCH).
* sp07/Makefile.am: Remove all-local: $(ARCH).
* sp08/Makefile.am: Remove all-local: $(ARCH).
* sp09/Makefile.am: Remove all-local: $(ARCH).
* sp11/Makefile.am: Remove all-local: $(ARCH).
* sp12/Makefile.am: Remove all-local: $(ARCH).
* sp13/Makefile.am: Remove all-local: $(ARCH).
* sp14/Makefile.am: Remove all-local: $(ARCH).
* sp15/Makefile.am: Remove all-local: $(ARCH).
* sp16/Makefile.am: Remove all-local: $(ARCH).
* sp17/Makefile.am: Remove all-local: $(ARCH).
* sp19/Makefile.am: Remove all-local: $(ARCH).
* sp20/Makefile.am: Remove all-local: $(ARCH).
* sp21/Makefile.am: Remove all-local: $(ARCH).
* sp22/Makefile.am: Remove all-local: $(ARCH).
* sp23/Makefile.am: Remove all-local: $(ARCH).
* sp24/Makefile.am: Remove all-local: $(ARCH).
* sp25/Makefile.am: Remove all-local: $(ARCH).
* sp26/Makefile.am: Remove all-local: $(ARCH).
* sp27/Makefile.am: Remove all-local: $(ARCH).
* sp28/Makefile.am: Remove all-local: $(ARCH).
* sp29/Makefile.am: Remove all-local: $(ARCH).
* sp30/Makefile.am: Remove all-local: $(ARCH).
* sp31/Makefile.am: Remove all-local: $(ARCH).
* sp32/Makefile.am: Remove all-local: $(ARCH).
* spfatal/Makefile.am: Remove all-local: $(ARCH).
* spsize/Makefile.am: Remove all-local: $(ARCH).
* sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c,
sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c,
sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc,
sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c,
sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c,
sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc,
sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c,
sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c,
sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h,
sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c,
sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c,
sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h,
sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c,
sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c,
sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c,
sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c,
sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c,
sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc,
sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c,
sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h,
sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c,
sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc,
sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c,
sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c,
sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h,
sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h,
sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c,
sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c,
sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h,
sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h,
sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc,
sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc,
sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c,
sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c,
sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c,
sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c,
sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c,
sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c,
sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c,
sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc,
sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c,
spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc,
spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c,
spsize/size.c, spsize/system.h: URL for license changed.
sp01/Makefile.am: Reflect having moved automake.
sp02/Makefile.am: Reflect having moved automake.
sp03/Makefile.am: Reflect having moved automake.
sp04/Makefile.am: Reflect having moved automake.
sp05/Makefile.am: Reflect having moved automake.
sp06/Makefile.am: Reflect having moved automake.
sp07/Makefile.am: Reflect having moved automake.
sp08/Makefile.am: Reflect having moved automake.
sp09/Makefile.am: Reflect having moved automake.
sp11/Makefile.am: Reflect having moved automake.
sp12/Makefile.am: Reflect having moved automake.
sp13/Makefile.am: Reflect having moved automake.
sp14/Makefile.am: Reflect having moved automake.
sp15/Makefile.am: Reflect having moved automake.
sp16/Makefile.am: Reflect having moved automake.
sp17/Makefile.am: Reflect having moved automake.
sp19/Makefile.am: Reflect having moved automake.
sp20/Makefile.am: Reflect having moved automake.
sp21/Makefile.am: Reflect having moved automake.
sp22/Makefile.am: Reflect having moved automake.
sp23/Makefile.am: Reflect having moved automake.
sp24/Makefile.am: Reflect having moved automake.
sp25/Makefile.am: Reflect having moved automake.
sp26/Makefile.am: Reflect having moved automake.
sp27/Makefile.am: Reflect having moved automake.
sp28/Makefile.am: Reflect having moved automake.
sp29/Makefile.am: Reflect having moved automake.
sp30/Makefile.am: Reflect having moved automake.
sp31/Makefile.am: Reflect having moved automake.
sp32/Makefile.am: Reflect having moved automake.
spfatal/Makefile.am: Reflect having moved automake.
spsize/Makefile.am: Reflect having moved automake.
* sp02/sp02.scn, sp15/sp15.scn, sp16/sp16.scn, sp20/sp20.scn,
sp22/sp22.scn, sp23/sp23.scn, sp25/sp25.scn, sp31/sp31.scn: Per PR239
update the IDs in the screens.
* sp01/Makefile.am: Use $(OBJEXT) instead of .o.
* sp02/Makefile.am: Use $(OBJEXT) instead of .o.
* sp03/Makefile.am: Use $(OBJEXT) instead of .o.
* sp04/Makefile.am: Use $(OBJEXT) instead of .o.
* sp05/Makefile.am: Use $(OBJEXT) instead of .o.
* sp06/Makefile.am: Use $(OBJEXT) instead of .o.
* sp07/Makefile.am: Use $(OBJEXT) instead of .o.
* sp08/Makefile.am: Use $(OBJEXT) instead of .o.
* sp09/Makefile.am: Use $(OBJEXT) instead of .o.
* sp11/Makefile.am: Use $(OBJEXT) instead of .o.
* sp12/Makefile.am: Use $(OBJEXT) instead of .o.
* sp13/Makefile.am: Use $(OBJEXT) instead of .o.
* sp14/Makefile.am: Use $(OBJEXT) instead of .o.
* sp15/Makefile.am: Use $(OBJEXT) instead of .o.
* sp16/Makefile.am: Use $(OBJEXT) instead of .o.
* sp17/Makefile.am: Use $(OBJEXT) instead of .o.
* sp19/Makefile.am: Use $(OBJEXT) instead of .o.
* sp20/Makefile.am: Use $(OBJEXT) instead of .o.
* sp21/Makefile.am: Use $(OBJEXT) instead of .o.
* sp22/Makefile.am: Use $(OBJEXT) instead of .o.
* sp23/Makefile.am: Use $(OBJEXT) instead of .o.
* sp24/Makefile.am: Use $(OBJEXT) instead of .o.
* sp25/Makefile.am: Use $(OBJEXT) instead of .o.
* sp26/Makefile.am: Use $(OBJEXT) instead of .o.
* sp27/Makefile.am: Use $(OBJEXT) instead of .o.
* sp28/Makefile.am: Use $(OBJEXT) instead of .o.
* sp29/Makefile.am: Use $(OBJEXT) instead of .o.
* sp30/Makefile.am: Use $(OBJEXT) instead of .o.
* sp31/Makefile.am: Use $(OBJEXT) instead of .o.
* spfatal/Makefile.am: Use $(OBJEXT) instead of .o.
* spsize/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* sp01/task1.c, sp02/task1.c, sp03/task2.c, sp04/task1.c, sp05/task1.c,
sp06/task1.c, sp07/taskexit.c, sp08/task1.c, sp09/task1.c,
sp11/task1.c, sp12/pritask.c, sp12/task5.c, sp13/task1.c,
sp14/task2.c, sp15/task1.c, sp16/task1.c, sp17/task1.c,
sp19/fptask.c, sp20/task1.c, sp21/task1.c, sp22/task1.c,
sp23/task1.c, sp24/task1.c, sp25/task1.c, sp26/init.c, sp26/task1.c,
sp30/task1.c, sp31/task1.c, spsize/init.c, spsize/size.c: Modified.
* sp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp15/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp16/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp17/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp19/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp21/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp22/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp23/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp24/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp25/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp26/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp27/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp28/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp29/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp30/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp31/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS.
* spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sp20/Makefile.am: include leaf.am instead of leaf.cfg.
* sp02/Makefile.am: include leaf.am instead of leaf.cfg.
* sp19/Makefile.am: include leaf.am instead of leaf.cfg.
* sp11/Makefile.am: include leaf.am instead of leaf.cfg.
* sp25/Makefile.am: include leaf.am instead of leaf.cfg.
* sp04/Makefile.am: include leaf.am instead of leaf.cfg.
* spsize/Makefile.am: include leaf.am instead of leaf.cfg.
* sp01/Makefile.am: include leaf.am instead of leaf.cfg.
* sp16/Makefile.am: include leaf.am instead of leaf.cfg.
* sp05/Makefile.am: include leaf.am instead of leaf.cfg.
* sp09/Makefile.am: include leaf.am instead of leaf.cfg.
* spfatal/Makefile.am: include leaf.am instead of leaf.cfg.
* sp06/Makefile.am: include leaf.am instead of leaf.cfg.
* sp23/Makefile.am: include leaf.am instead of leaf.cfg.
* sp28/Makefile.am: include leaf.am instead of leaf.cfg.
* sp03/Makefile.am: include leaf.am instead of leaf.cfg.
* sp29/Makefile.am: include leaf.am instead of leaf.cfg.
* sp13/Makefile.am: include leaf.am instead of leaf.cfg.
* sp27/Makefile.am: include leaf.am instead of leaf.cfg.
* sp14/Makefile.am: include leaf.am instead of leaf.cfg.
* sp07/Makefile.am: include leaf.am instead of leaf.cfg.
* sp15/Makefile.am: include leaf.am instead of leaf.cfg.
* sp17/Makefile.am: include leaf.am instead of leaf.cfg.
* sp22/Makefile.am: include leaf.am instead of leaf.cfg.
* sp12/Makefile.am: include leaf.am instead of leaf.cfg.
* sp26/Makefile.am: include leaf.am instead of leaf.cfg.
* sp21/Makefile.am: include leaf.am instead of leaf.cfg.
* sp24/Makefile.am: include leaf.am instead of leaf.cfg.
* sp08/Makefile.am: include leaf.am instead of leaf.cfg.
addition.
warnings.
like signal dispatching.
