path: root/testsuites/sptests/sp13/Makefile.am (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-111-1/+1
| | | | | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am, spsize/size.c: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-4/+2
* Convert to use *_PROGRAMS.Ralf Corsepius2005-11-131-12/+9
* Rework.Ralf Corsepius2005-11-111-29/+8
* Eliminate TEST.Ralf Corsepius2005-11-111-7/+6
* Expand sptests.am.Ralf Corsepius2005-11-111-1/+21
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-9/+6
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * sp02/Makefile.am: Ditto. * sp03/Makefile.am: Ditto. * sp04/Makefile.am: Ditto. * sp05/Makefile.am: Ditto. * sp06/Makefile.am: Ditto. * sp07/Makefile.am: Ditto. * sp08/Makefile.am: Ditto. * sp09/Makefile.am: Ditto. * sp11/Makefile.am: Ditto. * sp12/Makefile.am: Ditto. * sp13/Makefile.am: Ditto. * sp14/Makefile.am: Ditto. * sp15/Makefile.am: Ditto. * sp16/Makefile.am: Ditto. * sp17/Makefile.am: Ditto. * sp19/Makefile.am: Ditto. * sp20/Makefile.am: Ditto. * sp21/Makefile.am: Ditto. * sp22/Makefile.am: Ditto. * sp23/Makefile.am: Ditto. * sp24/Makefile.am: Ditto. * sp25/Makefile.am: Ditto. * sp26/Makefile.am: Ditto. * sp27/Makefile.am: Ditto. * sp28/Makefile.am: Ditto. * sp29/Makefile.am: Ditto. * sp30/Makefile.am: Ditto. * sp31/Makefile.am: Ditto. * sp32/Makefile.am: Ditto. * spfatal/Makefile.am: Ditto. * spsize/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Remove all-local: $(ARCH). * sp02/Makefile.am: Remove all-local: $(ARCH). * sp03/Makefile.am: Remove all-local: $(ARCH). * sp04/Makefile.am: Remove all-local: $(ARCH). * sp05/Makefile.am: Remove all-local: $(ARCH). * sp06/Makefile.am: Remove all-local: $(ARCH). * sp07/Makefile.am: Remove all-local: $(ARCH). * sp08/Makefile.am: Remove all-local: $(ARCH). * sp09/Makefile.am: Remove all-local: $(ARCH). * sp11/Makefile.am: Remove all-local: $(ARCH). * sp12/Makefile.am: Remove all-local: $(ARCH). * sp13/Makefile.am: Remove all-local: $(ARCH). * sp14/Makefile.am: Remove all-local: $(ARCH). * sp15/Makefile.am: Remove all-local: $(ARCH). * sp16/Makefile.am: Remove all-local: $(ARCH). * sp17/Makefile.am: Remove all-local: $(ARCH). * sp19/Makefile.am: Remove all-local: $(ARCH). * sp20/Makefile.am: Remove all-local: $(ARCH). * sp21/Makefile.am: Remove all-local: $(ARCH). * sp22/Makefile.am: Remove all-local: $(ARCH). * sp23/Makefile.am: Remove all-local: $(ARCH). * sp24/Makefile.am: Remove all-local: $(ARCH). * sp25/Makefile.am: Remove all-local: $(ARCH). * sp26/Makefile.am: Remove all-local: $(ARCH). * sp27/Makefile.am: Remove all-local: $(ARCH). * sp28/Makefile.am: Remove all-local: $(ARCH). * sp29/Makefile.am: Remove all-local: $(ARCH). * sp30/Makefile.am: Remove all-local: $(ARCH). * sp31/Makefile.am: Remove all-local: $(ARCH). * sp32/Makefile.am: Remove all-local: $(ARCH). * spfatal/Makefile.am: Remove all-local: $(ARCH). * spsize/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. sp01/Makefile.am: Reflect having moved automake. sp02/Makefile.am: Reflect having moved automake. sp03/Makefile.am: Reflect having moved automake. sp04/Makefile.am: Reflect having moved automake. sp05/Makefile.am: Reflect having moved automake. sp06/Makefile.am: Reflect having moved automake. sp07/Makefile.am: Reflect having moved automake. sp08/Makefile.am: Reflect having moved automake. sp09/Makefile.am: Reflect having moved automake. sp11/Makefile.am: Reflect having moved automake. sp12/Makefile.am: Reflect having moved automake. sp13/Makefile.am: Reflect having moved automake. sp14/Makefile.am: Reflect having moved automake. sp15/Makefile.am: Reflect having moved automake. sp16/Makefile.am: Reflect having moved automake. sp17/Makefile.am: Reflect having moved automake. sp19/Makefile.am: Reflect having moved automake. sp20/Makefile.am: Reflect having moved automake. sp21/Makefile.am: Reflect having moved automake. sp22/Makefile.am: Reflect having moved automake. sp23/Makefile.am: Reflect having moved automake. sp24/Makefile.am: Reflect having moved automake. sp25/Makefile.am: Reflect having moved automake. sp26/Makefile.am: Reflect having moved automake. sp27/Makefile.am: Reflect having moved automake. sp28/Makefile.am: Reflect having moved automake. sp29/Makefile.am: Reflect having moved automake. sp30/Makefile.am: Reflect having moved automake. sp31/Makefile.am: Reflect having moved automake. sp32/Makefile.am: Reflect having moved automake. spfatal/Makefile.am: Reflect having moved automake. spsize/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Use $(OBJEXT) instead of .o. * sp02/Makefile.am: Use $(OBJEXT) instead of .o. * sp03/Makefile.am: Use $(OBJEXT) instead of .o. * sp04/Makefile.am: Use $(OBJEXT) instead of .o. * sp05/Makefile.am: Use $(OBJEXT) instead of .o. * sp06/Makefile.am: Use $(OBJEXT) instead of .o. * sp07/Makefile.am: Use $(OBJEXT) instead of .o. * sp08/Makefile.am: Use $(OBJEXT) instead of .o. * sp09/Makefile.am: Use $(OBJEXT) instead of .o. * sp11/Makefile.am: Use $(OBJEXT) instead of .o. * sp12/Makefile.am: Use $(OBJEXT) instead of .o. * sp13/Makefile.am: Use $(OBJEXT) instead of .o. * sp14/Makefile.am: Use $(OBJEXT) instead of .o. * sp15/Makefile.am: Use $(OBJEXT) instead of .o. * sp16/Makefile.am: Use $(OBJEXT) instead of .o. * sp17/Makefile.am: Use $(OBJEXT) instead of .o. * sp19/Makefile.am: Use $(OBJEXT) instead of .o. * sp20/Makefile.am: Use $(OBJEXT) instead of .o. * sp21/Makefile.am: Use $(OBJEXT) instead of .o. * sp22/Makefile.am: Use $(OBJEXT) instead of .o. * sp23/Makefile.am: Use $(OBJEXT) instead of .o. * sp24/Makefile.am: Use $(OBJEXT) instead of .o. * sp25/Makefile.am: Use $(OBJEXT) instead of .o. * sp26/Makefile.am: Use $(OBJEXT) instead of .o. * sp27/Makefile.am: Use $(OBJEXT) instead of .o. * sp28/Makefile.am: Use $(OBJEXT) instead of .o. * sp29/Makefile.am: Use $(OBJEXT) instead of .o. * sp30/Makefile.am: Use $(OBJEXT) instead of .o. * sp31/Makefile.am: Use $(OBJEXT) instead of .o. * spfatal/Makefile.am: Use $(OBJEXT) instead of .o. * spsize/Makefile.am: Use $(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * sp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp15/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp16/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp17/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp19/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp20/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp21/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp22/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp23/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp24/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp25/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp26/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp27/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp28/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp29/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp30/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp31/Makefile.am: Remove AUTOMAKE_OPTIONS. * spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS. * spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+3
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+0
| | | | to fix some minor bugs in the conversion to automake.
* Converted to automake.Joel Sherrill1999-11-221-0/+40
