path: root/testsuites/sptests/sp12 (follow)
* sptests/sp12/pritask.c: Correct printf() warningJoel Sherrill2015-03-241-3/+4
* tests/sptests: Use <rtems/test.h>Sebastian Huber2014-03-253-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-2110-10/+10
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1111-25/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
* 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-07-242-30/+28
| | | | | | | | | | | | | * sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-228-0/+32
* Whitespace removal.Ralf Corsepius2009-11-301-1/+1
* Use PRIdrtems_task_argument to print rtems_task_argument's.Ralf Corsepius2009-10-271-1/+1
* Change Priority_Test_driver to use rtems_task_priority argument.Ralf Corsepius2009-10-261-1/+1
* Change Priority_Test_driver to use rtems_task_priority argument.Ralf Corsepius2009-10-261-3/+3
| | | | Use PRIdrtems_task_priority to print rtems_task_priority's.
* Use PRIdrtems_task_priority to print rtems_task_priority's.Ralf Corsepius2009-10-261-3/+3
* Use PRIxrtems_id to print rtems_ids.Ralf Corsepius2009-10-261-1/+1
* 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-123-14/+13
| | | | | | | | | | | | | | | * sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c, sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c, sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c, sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c, sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c, spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second().
* 2009-07-08 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-081-7/+7
| | | | | * sp12/sp12.scn: Update screen to reflect priority changes from long ago.
* 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-101-2/+2
| | | | | | | | | | | | | * sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c, sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h, spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c, spsize/size.c: Fix warnings.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-144-13/+15
| | | | | | | | | | | | * sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c, sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-011-1/+1
| | | | | | | | | | | | | * sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c, sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c, sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c, sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c, sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c, sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c, sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c, spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-072-2/+20
| | | | | | | | | | | * sp09/screen07.c, sp09/screen12.c, sp09/screen14.c, sp09/sp09.scn Add test cases for: + message queue create requesting too many message buffers for the available memory + region extend with address inside existing heap + timer server initiate too large a stack, create error * sp12/pritask.c, sp12/sp12.scn: Add test cases for: + task set priority while holding resource
* 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-111-1/+1
| | | | | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am, spsize/size.c: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-4/+2
* Convert to use *_PROGRAMS.Ralf Corsepius2005-11-131-12/+9
* Rework.Ralf Corsepius2005-11-111-29/+8
* Eliminate TEST.Ralf Corsepius2005-11-111-7/+6
* Expand sptests.am.Ralf Corsepius2005-11-111-1/+21
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-9/+7
* Remove stray white spaces.Ralf Corsepius2004-04-161-11/+11
* * sp01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-011-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp15/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp16/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp17/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp19/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp20/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp21/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp22/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp23/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp24/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp25/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp26/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp27/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp28/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp29/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp30/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp31/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * sp32/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * spfatal/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * spsize/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-303-4/+4
| | | | | | | | | | | | | | * sp02/task1.c, sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp05/task1.c, sp06/task1.c, sp09/screen01.c, sp09/screen07.c, sp09/screen12.c, sp09/system.h, sp09/task3.c, sp11/task1.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/system.h, sp15/system.h, sp16/system.h, sp17/system.h, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/system.h, sp19/task1.c, sp20/init.c, sp20/system.h, sp20/task1.c, sp23/system.h, sp24/init.c, sp25/system.h, sp30/init.c, spfatal/fatal.c, spfatal/puterr.c, spfatal/system.h, spsize/size.c: Convert to using c99 fixed size types.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * sp02/Makefile.am: Ditto. * sp03/Makefile.am: Ditto. * sp04/Makefile.am: Ditto. * sp05/Makefile.am: Ditto. * sp06/Makefile.am: Ditto. * sp07/Makefile.am: Ditto. * sp08/Makefile.am: Ditto. * sp09/Makefile.am: Ditto. * sp11/Makefile.am: Ditto. * sp12/Makefile.am: Ditto. * sp13/Makefile.am: Ditto. * sp14/Makefile.am: Ditto. * sp15/Makefile.am: Ditto. * sp16/Makefile.am: Ditto. * sp17/Makefile.am: Ditto. * sp19/Makefile.am: Ditto. * sp20/Makefile.am: Ditto. * sp21/Makefile.am: Ditto. * sp22/Makefile.am: Ditto. * sp23/Makefile.am: Ditto. * sp24/Makefile.am: Ditto. * sp25/Makefile.am: Ditto. * sp26/Makefile.am: Ditto. * sp27/Makefile.am: Ditto. * sp28/Makefile.am: Ditto. * sp29/Makefile.am: Ditto. * sp30/Makefile.am: Ditto. * sp31/Makefile.am: Ditto. * sp32/Makefile.am: Ditto. * spfatal/Makefile.am: Ditto. * spsize/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Remove all-local: $(ARCH). * sp02/Makefile.am: Remove all-local: $(ARCH). * sp03/Makefile.am: Remove all-local: $(ARCH). * sp04/Makefile.am: Remove all-local: $(ARCH). * sp05/Makefile.am: Remove all-local: $(ARCH). * sp06/Makefile.am: Remove all-local: $(ARCH). * sp07/Makefile.am: Remove all-local: $(ARCH). * sp08/Makefile.am: Remove all-local: $(ARCH). * sp09/Makefile.am: Remove all-local: $(ARCH). * sp11/Makefile.am: Remove all-local: $(ARCH). * sp12/Makefile.am: Remove all-local: $(ARCH). * sp13/Makefile.am: Remove all-local: $(ARCH). * sp14/Makefile.am: Remove all-local: $(ARCH). * sp15/Makefile.am: Remove all-local: $(ARCH). * sp16/Makefile.am: Remove all-local: $(ARCH). * sp17/Makefile.am: Remove all-local: $(ARCH). * sp19/Makefile.am: Remove all-local: $(ARCH). * sp20/Makefile.am: Remove all-local: $(ARCH). * sp21/Makefile.am: Remove all-local: $(ARCH). * sp22/Makefile.am: Remove all-local: $(ARCH). * sp23/Makefile.am: Remove all-local: $(ARCH). * sp24/Makefile.am: Remove all-local: $(ARCH). * sp25/Makefile.am: Remove all-local: $(ARCH). * sp26/Makefile.am: Remove all-local: $(ARCH). * sp27/Makefile.am: Remove all-local: $(ARCH). * sp28/Makefile.am: Remove all-local: $(ARCH). * sp29/Makefile.am: Remove all-local: $(ARCH). * sp30/Makefile.am: Remove all-local: $(ARCH). * sp31/Makefile.am: Remove all-local: $(ARCH). * sp32/Makefile.am: Remove all-local: $(ARCH). * spfatal/Makefile.am: Remove all-local: $(ARCH). * spsize/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-0410-10/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. sp01/Makefile.am: Reflect having moved automake. sp02/Makefile.am: Reflect having moved automake. sp03/Makefile.am: Reflect having moved automake. sp04/Makefile.am: Reflect having moved automake. sp05/Makefile.am: Reflect having moved automake. sp06/Makefile.am: Reflect having moved automake. sp07/Makefile.am: Reflect having moved automake. sp08/Makefile.am: Reflect having moved automake. sp09/Makefile.am: Reflect having moved automake. sp11/Makefile.am: Reflect having moved automake. sp12/Makefile.am: Reflect having moved automake. sp13/Makefile.am: Reflect having moved automake. sp14/Makefile.am: Reflect having moved automake. sp15/Makefile.am: Reflect having moved automake. sp16/Makefile.am: Reflect having moved automake. sp17/Makefile.am: Reflect having moved automake. sp19/Makefile.am: Reflect having moved automake. sp20/Makefile.am: Reflect having moved automake. sp21/Makefile.am: Reflect having moved automake. sp22/Makefile.am: Reflect having moved automake. sp23/Makefile.am: Reflect having moved automake. sp24/Makefile.am: Reflect having moved automake. sp25/Makefile.am: Reflect having moved automake. sp26/Makefile.am: Reflect having moved automake. sp27/Makefile.am: Reflect having moved automake. sp28/Makefile.am: Reflect having moved automake. sp29/Makefile.am: Reflect having moved automake. sp30/Makefile.am: Reflect having moved automake. sp31/Makefile.am: Reflect having moved automake. sp32/Makefile.am: Reflect having moved automake. spfatal/Makefile.am: Reflect having moved automake. spsize/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Use $(OBJEXT) instead of .o. * sp02/Makefile.am: Use $(OBJEXT) instead of .o. * sp03/Makefile.am: Use $(OBJEXT) instead of .o. * sp04/Makefile.am: Use $(OBJEXT) instead of .o. * sp05/Makefile.am: Use $(OBJEXT) instead of .o. * sp06/Makefile.am: Use $(OBJEXT) instead of .o. * sp07/Makefile.am: Use $(OBJEXT) instead of .o. * sp08/Makefile.am: Use $(OBJEXT) instead of .o. * sp09/Makefile.am: Use $(OBJEXT) instead of .o. * sp11/Makefile.am: Use $(OBJEXT) instead of .o. * sp12/Makefile.am: Use $(OBJEXT) instead of .o. * sp13/Makefile.am: Use $(OBJEXT) instead of .o. * sp14/Makefile.am: Use $(OBJEXT) instead of .o. * sp15/Makefile.am: Use $(OBJEXT) instead of .o. * sp16/Makefile.am: Use $(OBJEXT) instead of .o. * sp17/Makefile.am: Use $(OBJEXT) instead of .o. * sp19/Makefile.am: Use $(OBJEXT) instead of .o. * sp20/Makefile.am: Use $(OBJEXT) instead of .o. * sp21/Makefile.am: Use $(OBJEXT) instead of .o. * sp22/Makefile.am: Use $(OBJEXT) instead of .o. * sp23/Makefile.am: Use $(OBJEXT) instead of .o. * sp24/Makefile.am: Use $(OBJEXT) instead of .o. * sp25/Makefile.am: Use $(OBJEXT) instead of .o. * sp26/Makefile.am: Use $(OBJEXT) instead of .o. * sp27/Makefile.am: Use $(OBJEXT) instead of .o. * sp28/Makefile.am: Use $(OBJEXT) instead of .o. * sp29/Makefile.am: Use $(OBJEXT) instead of .o. * sp30/Makefile.am: Use $(OBJEXT) instead of .o. * sp31/Makefile.am: Use $(OBJEXT) instead of .o. * spfatal/Makefile.am: Use $(OBJEXT) instead of .o. * spsize/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-022-2/+2
| | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * sp01/task1.c, sp02/task1.c, sp03/task2.c, sp04/task1.c, sp05/task1.c, sp06/task1.c, sp07/taskexit.c, sp08/task1.c, sp09/task1.c, sp11/task1.c, sp12/pritask.c, sp12/task5.c, sp13/task1.c, sp14/task2.c, sp15/task1.c, sp16/task1.c, sp17/task1.c, sp19/fptask.c, sp20/task1.c, sp21/task1.c, sp22/task1.c, sp23/task1.c, sp24/task1.c, sp25/task1.c, sp26/init.c, sp26/task1.c, sp30/task1.c, sp31/task1.c, spsize/init.c, spsize/size.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * sp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp15/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp16/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp17/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp19/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp20/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp21/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp22/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp23/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp24/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp25/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp26/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp27/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp28/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp29/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp30/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp31/Makefile.am: Remove AUTOMAKE_OPTIONS. * spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS. * spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+6
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Changed screen to reflect change in object class numbers with ITRONJoel Sherrill2000-01-051-1/+1
| | | | addition.
