path: root/testsuites/sptests/sp11 (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+65
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-117-0/+858
