* | sptests: refactored sp09/screen14.c into two new tests | Daniel Ramirez | 2013-12-11 | 1 | -368/+0 |
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | Whitespace removal. | Ralf Corsepius | 2009-11-30 | 1 | -3/+3 |
* | 2009-09-28 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2009-09-28 | 1 | -4/+84 |
| | | | | | | | * sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen05.c, sp09/screen09.c, sp09/screen14.c, sp09/sp09.scn, sp28/init.c, sp28/sp28.scn, sp43/init.c: Add more error cases uncovered by uC5282 coverage runs. | ||||
* | 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-12 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | * sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/task2.c, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/task1.c, sp06/task2.c, sp09/screen02.c, sp09/screen04.c, sp09/screen06.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp12/task1.c, sp13/task1.c, sp13/task2.c, sp14/task1.c, sp16/task1.c, sp16/task4.c, sp19/fptask.c, sp19/task1.c, sp22/task1.c, sp24/task1.c, sp26/task1.c, sp29/init.c, sp30/task1.c, sp31/task1.c, sp33/init.c, sp45/init.c, sp46/init.c, sp50/init.c, spintrcritical06/init.c, spwatchdog/task1.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second(). | ||||
* | 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-08-10 | 1 | -7/+8 |
| | | | | | | | | | | | | * sp01/sp01.scn, sp01/task1.c, sp03/task1.c, sp03/task2.c, sp04/task1.c, sp04/tswitch.c, sp09/screen02.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.scn, sp11/sp11.scn, sp11/task1.c, sp11/task2.c, sp19/fptask.c, sp19/sp19.scn, sp19/task1.c, sp22/prtime.c, sp22/sp22.scn, sp22/task1.c, sp24/sp24.scn, sp24/task1.c, sp30/task1.c, sp31/prtime.c, sp31/sp31.scn, sp31/task1.c, spwatchdog/prtime.c, spwatchdog/spwatchdog.scn, spwatchdog/task1.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..). | ||||
* | 2009-01-05 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-01-05 | 1 | -7/+17 |
| | | | | | | * sp09/screen05.c, sp09/screen07.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen14.c: Use rtems_build_id rather than hard-coded hex numbers for bad object Ids. | ||||
* | 2008-10-14 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-10-14 | 1 | -8/+17 |
| | | | | | | | | | | | * sp09/screen07.c: Use INT_MAX as number of messages so always properly sized and no overflow on constant. * sp09/screen10.c: Delay so on targets with simulator idle clock tick driver this will work. * sp09/screen11.c, sp09/system.h: Move badly aligned objects to odd byte boundaries rather than two byte boundaries. * sp09/screen03.c, sp09/screen14.c: Skip tests which try to allocate more memory than size_t holds on m32c. | ||||
* | 2008-02-22 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-02-22 | 1 | -1/+1 |
| | | | | | | * sp09/screen01.c: Correct test. * sp09/screen14.c: Update copyright. * sp28/init.c: Correct end of test messages. | ||||
* | 2008-01-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-01-07 | 1 | -1/+13 |
| | | | | | | | | | | | * sp09/screen07.c, sp09/screen12.c, sp09/screen14.c, sp09/sp09.scn Add test cases for: + message queue create requesting too many message buffers for the available memory + region extend with address inside existing heap + timer server initiate too large a stack, create error * sp12/pritask.c, sp12/sp12.scn: Add test cases for: + task set priority while holding resource | ||||
* | 2007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-11-27 | 1 | -2/+11 |
| | | | | | | | * sp07/sp07.scn, sp07/task1.c, sp09/screen01.c, sp09/screen05.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen14.c, sp09/sp09.scn, sp25/sp25.scn, sp25/task1.c: Added several test cases to improve test coverage. | ||||
* | 2007-10-18 Glenn Humphrey <glenn.humphrey@OARcorp.com> | Glenn Humphrey | 2007-10-18 | 1 | -2/+2 |
| | | | | | | * sp09/screen06.c, sp09/screen14.c, sp13/sp13.scn, sp13/task1.c, sp16/sp16.scn: Corrected some minor mistakes and regenerated some .scn files. | ||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-16 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/init.c, sp01/sp01.doc, sp01/system.h, sp01/task1.c, sp02/init.c, sp02/preempt.c, sp02/sp02.doc, sp02/system.h, sp02/task1.c, sp02/task2.c, sp02/task3.c, sp03/init.c, sp03/sp03.doc, sp03/system.h, sp03/task1.c, sp03/task2.c, sp04/init.c, sp04/sp04.doc, sp04/system.h, sp04/task1.c, sp04/task2.c, sp04/task3.c, sp04/tswitch.c, sp05/init.c, sp05/sp05.doc, sp05/system.h, sp05/task1.c, sp05/task2.c, sp05/task3.c, sp06/init.c, sp06/sp06.doc, sp06/system.h, sp06/task1.c, sp06/task2.c, sp06/task3.c, sp07/init.c, sp07/sp07.doc, sp07/system.h, sp07/task1.c, sp07/task2.c, sp07/task3.c, sp07/task4.c, sp07/taskexit.c, sp07/tcreate.c, sp07/tdelete.c, sp07/trestart.c, sp07/tstart.c, sp08/init.c, sp08/sp08.doc, sp08/system.h, sp08/task1.c, sp09/delay.c, sp09/init.c, sp09/isr.c, sp09/screen01.c, sp09/screen02.c, sp09/screen03.c, sp09/screen04.c, sp09/screen05.c, sp09/screen06.c, sp09/screen07.c, sp09/screen08.c, sp09/screen09.c, sp09/screen10.c, sp09/screen11.c, sp09/screen12.c, sp09/screen13.c, sp09/screen14.c, sp09/sp09.doc, sp09/system.h, sp09/task1.c, sp09/task2.c, sp09/task3.c, sp09/task4.c, sp11/init.c, sp11/sp11.doc, sp11/system.h, sp11/task1.c, sp11/task2.c, sp11/timer.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/sp12.doc, sp12/system.h, sp12/task1.c, sp12/task2.c, sp12/task3.c, sp12/task4.c, sp12/task5.c, sp13/fillbuff.c, sp13/init.c, sp13/putbuff.c, sp13/sp13.doc, sp13/system.h, sp13/task1.c, sp13/task2.c, sp13/task3.c, sp14/asr.c, sp14/init.c, sp14/sp14.doc, sp14/system.h, sp14/task1.c, sp14/task2.c, sp15/init.c, sp15/sp15.doc, sp15/system.h, sp15/task1.c, sp16/init.c, sp16/sp16.doc, sp16/system.h, sp16/task1.c, sp16/task2.c, sp16/task3.c, sp16/task4.c, sp16/task5.c, sp17/asr.c, sp17/init.c, sp17/sp17.doc, sp17/system.h, sp17/task1.c, sp17/task2.c, sp19/first.c, sp19/fptask.c, sp19/fptest.h, sp19/init.c, sp19/inttest.h, sp19/sp19.doc, sp19/system.h, sp19/task1.c, sp20/getall.c, sp20/init.c, sp20/sp20.doc, sp20/system.h, sp20/task1.c, sp21/init.c, sp21/sp21.doc, sp21/system.h, sp21/task1.c, sp22/delay.c, sp22/init.c, sp22/prtime.c, sp22/sp22.doc, sp22/system.h, sp22/task1.c, sp23/init.c, sp23/sp23.doc, sp23/system.h, sp23/task1.c, sp24/init.c, sp24/resume.c, sp24/sp24.doc, sp24/system.h, sp24/task1.c, sp25/init.c, sp25/sp25.doc, sp25/system.h, sp25/task1.c, sp26/init.c, sp26/sp26.doc, sp26/system.h, sp26/task1.c, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/system.h, sp30/task1.c, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/system.h, sp31/task1.c, sp32/init.c, spfatal/fatal.c, spfatal/init.c, spfatal/puterr.c, spfatal/spfatal.doc, spfatal/system.h, spfatal/task1.c, spsize/getint.c, spsize/init.c, spsize/size.c, spsize/system.h: URL for license changed. | ||||
* | 2001-01-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-22 | 1 | -1/+11 |
| | | | | | * sp09/screen14.c, sp09/sp09.scn, sp30/init.c, sp31/init.c: Modified because priority added as argument to rtems_timer_initiate_server(). | ||||
* | 2001-01-16 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-16 | 1 | -0/+82 |
| | | | | | | | | | | | | | * Added tests for task-based timers. This included the new tests sp30 and sp31. * Makefile.am, configure.ac: Modified to reflect new tests and files. * sp09/screen14.c, sp09/sp09.scn: Modified to add error checks for task-based timer services. * sp30/.cvsignore, sp30/Makefile.am, sp30/init.c, sp30/resume.c, sp30/sp30.doc, sp30/sp30.scn, sp30/system.h, sp30/task1.c, sp31/.cvsignore, sp31/Makefile.am, sp31/delay.c, sp31/init.c, sp31/prtime.c, sp31/sp31.doc, sp31/sp31.scn, sp31/system.h, sp31/task1.c: New files. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -8/+0 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+162 |
