path: root/testsuites/sptests/sp07 (follow)
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp01/Makefile.am: Use $(OBJEXT) instead of .o. * sp02/Makefile.am: Use $(OBJEXT) instead of .o. * sp03/Makefile.am: Use $(OBJEXT) instead of .o. * sp04/Makefile.am: Use $(OBJEXT) instead of .o. * sp05/Makefile.am: Use $(OBJEXT) instead of .o. * sp06/Makefile.am: Use $(OBJEXT) instead of .o. * sp07/Makefile.am: Use $(OBJEXT) instead of .o. * sp08/Makefile.am: Use $(OBJEXT) instead of .o. * sp09/Makefile.am: Use $(OBJEXT) instead of .o. * sp11/Makefile.am: Use $(OBJEXT) instead of .o. * sp12/Makefile.am: Use $(OBJEXT) instead of .o. * sp13/Makefile.am: Use $(OBJEXT) instead of .o. * sp14/Makefile.am: Use $(OBJEXT) instead of .o. * sp15/Makefile.am: Use $(OBJEXT) instead of .o. * sp16/Makefile.am: Use $(OBJEXT) instead of .o. * sp17/Makefile.am: Use $(OBJEXT) instead of .o. * sp19/Makefile.am: Use $(OBJEXT) instead of .o. * sp20/Makefile.am: Use $(OBJEXT) instead of .o. * sp21/Makefile.am: Use $(OBJEXT) instead of .o. * sp22/Makefile.am: Use $(OBJEXT) instead of .o. * sp23/Makefile.am: Use $(OBJEXT) instead of .o. * sp24/Makefile.am: Use $(OBJEXT) instead of .o. * sp25/Makefile.am: Use $(OBJEXT) instead of .o. * sp26/Makefile.am: Use $(OBJEXT) instead of .o. * sp27/Makefile.am: Use $(OBJEXT) instead of .o. * sp28/Makefile.am: Use $(OBJEXT) instead of .o. * sp29/Makefile.am: Use $(OBJEXT) instead of .o. * sp30/Makefile.am: Use $(OBJEXT) instead of .o. * sp31/Makefile.am: Use $(OBJEXT) instead of .o. * spfatal/Makefile.am: Use $(OBJEXT) instead of .o. * spsize/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-1/+1
| | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * sp01/task1.c, sp02/task1.c, sp03/task2.c, sp04/task1.c, sp05/task1.c, sp06/task1.c, sp07/taskexit.c, sp08/task1.c, sp09/task1.c, sp11/task1.c, sp12/pritask.c, sp12/task5.c, sp13/task1.c, sp14/task2.c, sp15/task1.c, sp16/task1.c, sp17/task1.c, sp19/fptask.c, sp20/task1.c, sp21/task1.c, sp22/task1.c, sp23/task1.c, sp24/task1.c, sp25/task1.c, sp26/init.c, sp26/task1.c, sp30/task1.c, sp31/task1.c, spsize/init.c, spsize/size.c: Modified.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * sp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * sp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp15/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp16/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp17/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp19/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp20/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp21/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp22/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp23/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp24/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp25/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp26/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp27/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp28/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp29/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp30/Makefile.am: Remove AUTOMAKE_OPTIONS. * sp31/Makefile.am: Remove AUTOMAKE_OPTIONS. * spfatal/Makefile.am: Remove AUTOMAKE_OPTIONS. * spsize/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * sp20/Makefile.am: include leaf.am instead of leaf.cfg. * sp02/Makefile.am: include leaf.am instead of leaf.cfg. * sp19/Makefile.am: include leaf.am instead of leaf.cfg. * sp11/Makefile.am: include leaf.am instead of leaf.cfg. * sp25/Makefile.am: include leaf.am instead of leaf.cfg. * sp04/Makefile.am: include leaf.am instead of leaf.cfg. * spsize/Makefile.am: include leaf.am instead of leaf.cfg. * sp01/Makefile.am: include leaf.am instead of leaf.cfg. * sp16/Makefile.am: include leaf.am instead of leaf.cfg. * sp05/Makefile.am: include leaf.am instead of leaf.cfg. * sp09/Makefile.am: include leaf.am instead of leaf.cfg. * spfatal/Makefile.am: include leaf.am instead of leaf.cfg. * sp06/Makefile.am: include leaf.am instead of leaf.cfg. * sp23/Makefile.am: include leaf.am instead of leaf.cfg. * sp28/Makefile.am: include leaf.am instead of leaf.cfg. * sp03/Makefile.am: include leaf.am instead of leaf.cfg. * sp29/Makefile.am: include leaf.am instead of leaf.cfg. * sp13/Makefile.am: include leaf.am instead of leaf.cfg. * sp27/Makefile.am: include leaf.am instead of leaf.cfg. * sp14/Makefile.am: include leaf.am instead of leaf.cfg. * sp07/Makefile.am: include leaf.am instead of leaf.cfg. * sp15/Makefile.am: include leaf.am instead of leaf.cfg. * sp17/Makefile.am: include leaf.am instead of leaf.cfg. * sp22/Makefile.am: include leaf.am instead of leaf.cfg. * sp12/Makefile.am: include leaf.am instead of leaf.cfg. * sp26/Makefile.am: include leaf.am instead of leaf.cfg. * sp21/Makefile.am: include leaf.am instead of leaf.cfg. * sp24/Makefile.am: include leaf.am instead of leaf.cfg. * sp08/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am: Include compile.am
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-7/+6
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+0
| | | | to fix some minor bugs in the conversion to automake.
* Converted to automake.Joel Sherrill1999-11-221-0/+41
* Updated copyright notice.Joel Sherrill1999-11-1712-24/+12
* Added CONFIGURE_EXTRA_TASK_STACKS definition to make memory requirementsJoel Sherrill1998-04-271-0/+2
| | | | more accurate.
* Increased stack space to let test run to completion.Joel Sherrill1998-02-201-4/+4
* updated copyright to 1998Joel Sherrill1998-02-1712-12/+12
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-0812-24/+24
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-2212-60/+60
* extended Task_id and Task_name arrays to avoid indexing past end of array.Joel Sherrill1996-09-171-2/+2
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The name of the test support routine pause was changed to rtems_test_pauseJoel Sherrill1996-02-221-1/+1
| | | | to avoid conflict with the standard POSIX routine pause(2).
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-4/+4
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-113-13/+63
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-1113-0/+635
