path: root/testsuites/sptests/sp07 (unfollow)
2020-04-17sapi: Add param check to rtems_extension_create()Sebastian Huber1-0/+5
Check that the extensions table is not NULL. Change format. Update #3953.
2020-02-25config: Remove CONFIGURE_DISABLE_SMP_CONFIGURATIONSebastian Huber1-2/+0
The CONFIGURE_DISABLE_SMP_CONFIGURATION configuration option and rtems_configuration_is_smp_enabled() were added during the SMP support development cycle as a workaround to fix some testsuite failures in SMP configurations. All use cases were replaced with tests for specific conditions. The configuration option and test macro were undocumented. Close #3876.
2019-12-04testsuites: Remove rtems_test_pause*()Sebastian Huber2-3/+0
The rtems_test_pause() and rtems_test_pause_and_screen_number() macros had different implementations depending on the RTEMS_TEST_NO_PAUSE define. This define was defined to 1 by default. The user was able to change this via the undocumented --disable-test-no-pause configure command line option. Pausing tests and waiting for user input contradicts the goal of having automated test runs. Remove this feature. Update #3818.
2018-10-05tests: Use rtems_task_exit()Sebastian Huber3-7/+3
Update #3533.
2018-04-10testsuite/sptests: Merged nested Makefile.am files into one Makefile.amChris Johns1-23/+0
This change is part of the testsuite Makefile.am reorganization. Update #3382
2017-11-06tests: Use simple console driverSebastian Huber1-1/+1
Update #3170. Update #3199.
2017-10-28tests: Remove TEST_INITSebastian Huber1-2/+0
The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
2017-10-23testsuite: Use printk for all test output where possible.Chris Johns1-0/+2
- Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
2017-05-11confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATIONSebastian Huber1-0/+2
Enable the SMP configuration by default in case SMP is enabled. Add configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it explicitly. Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail otherwise. Update #3001.
2016-01-04sptests/sp07: Fix test caseSebastian Huber2-13/+7
Fix things broken by commit d5154d0f6a04f3b7ed59d9a09038576fe2640756. Update #2493.
2015-12-24api: Remove deprecated NotepadsAun-Ali Zaidi5-62/+0
Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493.
2015-03-17tm07: Split some code into new spnotepad02.Joel Sherrill4-21/+27
Use of deprecated notepads in sp07 needs further work. Updates #2305.
2015-03-10cpukit: deprecate notepadsGedare Bloom1-0/+2
Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265
2014-09-16sptests/sp07: Minimize thread dispatch latencySebastian Huber11-157/+71
Do not use sprintf() in thread dispatch critical sections to avoid corruption of profiling samples. Update test to reflect thread the life cycle changes.
2014-03-25tests/sptests: Use <rtems/test.h>Sebastian Huber3-2/+6
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns13-13/+13
2013-12-28Test suite documentations corrections and fixes.Toma Radu1-15/+18
Correct the sp02.doc, sp05.doc, sp06.doc, sp07.doc, sp08.doc files.
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill13-29/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+5
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04Remove CVS-Ids.Ralf Corsépius1-5/+0
2012-05-03sp07/buffered_io.c add missing copyrightJoel Sherrill1-1/+6
Date and ownership determined from file history.
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+1
PR 1589/build * sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp08/Makefile.am, sp09/Makefile.am, sp10/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp18/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp2038/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp27/Makefile.am, sp27a/Makefile.am, sp28/Makefile.am, sp29/Makefile.am, sp30/Makefile.am, sp31/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, sp36/Makefile.am, sp37/Makefile.am, sp38/Makefile.am, sp39/Makefile.am, sp40/Makefile.am, sp41/Makefile.am, sp42/Makefile.am, sp43/Makefile.am, sp44/Makefile.am, sp45/Makefile.am, sp46/Makefile.am, sp47/Makefile.am, sp48/Makefile.am, sp49/Makefile.am, sp50/Makefile.am, sp51/Makefile.am, sp52/Makefile.am, sp53/Makefile.am, sp54/Makefile.am, sp55/Makefile.am, sp56/Makefile.am, sp57/Makefile.am, sp58/Makefile.am, sp59/Makefile.am, sp60/Makefile.am, sp62/Makefile.am, sp63/Makefile.am, sp64/Makefile.am, sp65/Makefile.am, sp66/Makefile.am, sp67/Makefile.am, sp68/Makefile.am, sp69/Makefile.am, sp70/Makefile.am, sp71/Makefile.am, sp72/Makefile.am, sp73/Makefile.am, sp74/Makefile.am, sp75/Makefile.am, sp76/Makefile.am, spassoc01/Makefile.am, spcbssched01/Makefile.am, spcbssched02/Makefile.am, spcbssched03/Makefile.am, spchain/Makefile.am, spclockget/Makefile.am, spcoverage/Makefile.am, spedfsched01/Makefile.am, spedfsched02/Makefile.am, spedfsched03/Makefile.am, sperror01/Makefile.am, sperror02/Makefile.am, sperror03/Makefile.am, spfatal01/Makefile.am, spfatal02/Makefile.am, spfatal03/Makefile.am, spfatal04/Makefile.am, spfatal05/Makefile.am, spfatal06/Makefile.am, spfatal07/Makefile.am, spfatal08/Makefile.am, spfatal09/Makefile.am, spfatal10/Makefile.am, spfatal11/Makefile.am, spfatal12/Makefile.am, spfatal13/Makefile.am, spfatal14/Makefile.am, spfatal15/Makefile.am, spfatal16/Makefile.am, spfatal17/Makefile.am, spfatal18/Makefile.am, spfatal19/Makefile.am, spfatal20/Makefile.am, spfatal21/Makefile.am, spfatal22/Makefile.am, spfatal23/Makefile.am, spfatal24/Makefile.am, spfatal25/Makefile.am, spfifo01/Makefile.am, spfifo02/Makefile.am, spfifo03/Makefile.am, spfifo04/Makefile.am, spfifo05/Makefile.am, spheapprot/Makefile.am, spintrcritical01/Makefile.am, spintrcritical02/Makefile.am, spintrcritical03/Makefile.am, spintrcritical04/Makefile.am, spintrcritical05/Makefile.am, spintrcritical06/Makefile.am, spintrcritical07/Makefile.am, spintrcritical08/Makefile.am, spintrcritical09/Makefile.am, spintrcritical10/Makefile.am, spintrcritical11/Makefile.am, spintrcritical12/Makefile.am, spintrcritical13/Makefile.am, spintrcritical14/Makefile.am, spintrcritical15/Makefile.am, spintrcritical16/Makefile.am, spintrcritical17/Makefile.am, spmkdir/Makefile.am, spmountmgr01/Makefile.am, spnotepad01/Makefile.am, spnsext01/Makefile.am, spobjgetnext/Makefile.am, spprintk/Makefile.am, spprivenv01/Makefile.am, sprbtree01/Makefile.am, spsimplesched01/Makefile.am, spsimplesched02/Makefile.am, spsimplesched03/Makefile.am, spsize/Makefile.am, spstkalloc/Makefile.am, spthreadq01/Makefile.am, spwatchdog/Makefile.am, spwkspace/Makefile.am: Remove obsolete optional manager capability.
2011-07-242011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-34/+27
* sp04/tswitch.c, sp07/task1.c, sp07/task2.c, sp09/screen07.c, sp11/task1.c, sp11/task2.c, sp12/pridrv.c, sp12/pritask.c, sp13/task1.c, sp14/asr.c, sp14/task1.c, sp19/first.c, sp19/fptask.c, sp19/inttest.h, sp19/task1.c, sp20/task1.c, sp25/task1.c, sp26/task1.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp32/init.c, sp33/init.c, sp34/changepri.c, sp36/strict_order_mut.c, sp37/init.c, sp43/init.c, sp44/init.c, sp48/init.c, sp54/init.c, sp59/init.c, sp65/init.c, sp68/init.c, spchain/init.c, spclockget/init.c, spfatal03/testcase.h, spfatal07/testcase.h, spfatal_support/init.c: Do not line length exceed 80 columns.
2011-03-102011-03-10 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber1-0/+42
* sp07/init.c: Improve coverage.
2011-02-22Add HAVE_CONFIG_H.Ralf Corsepius11-0/+44
2009-11-30Whitespace removal.Ralf Corsepius4-4/+4
2009-10-27Duplicate code from rtems_name_to_characters to convert rtems_name's into ↵Ralf Corsepius4-20/+44
char arrays.
2009-10-26Use PRIdrtems_task_priority to print rtems_task_priority's.Ralf Corsepius2-7/+7
2009-10-042009-10-04 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2-16/+10
* sp07/init.c, sp07/sp07.scn, sp09/init.c, sp09/screen01.c, sp09/sp09.scn, sp28/init.c, sp62/init.c, sp62/sp62.scn, sp64/init.c, sp64/sp64.scn: Add more test cases highlighted on SPARC at -O2, x86 at -Os and m68k at -Os. Fix typos.
2009-09-262009-09-26 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill4-11/+11
* sp04/tswitch.c, sp07/system.h, sp07/taskexit.c, sp07/tdelete.c, sp07/tstart.c, spfatal_support/init.c, spfatal_support/system.h: Eliminate use of deprecated rtems_extension.
2009-05-102009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+3
* sp04/system.h, sp04/task1.c, sp04/tswitch.c, sp07/init.c, sp12/init.c, sp13/putbuff.c, sp13/system.h, sp13/task1.c, sp15/init.c, sp16/system.h, sp19/fptask.c, sp25/system.h, sp26/task1.c, sp27/init.c, sp28/init.c, sp29/init.c, sp31/task1.c, sp33/init.c, sp34/changepri.c, sp35/priinv.c, sp37/init.c, sp38/init.c, sp39/init.c, sp41/init.c, sp42/init.c, sp43/init.c, sp44/init.c, sp45/init.c, sp46/init.c, sp47/init.c, sp48/init.c, spfatal03/testcase.h, spfatal05/testcase.h, spfatal06/testcase.h, spfatal_support/system.h, spobjgetnext/init.c, spsize/getint.c, spsize/size.c: Fix warnings.
2009-04-03Eliminate _exe_/.exe.Ralf Corsepius1-7/+7
2008-12-142008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+5
* sp07/init.c, sp12/init.c, sp12/pridrv.c, sp12/pritask.c, sp12/system.h, sp16/system.h, sp25/system.h, sp26/task1.c, sp28/init.c, sp29/init.c, sp35/priinv.c, sp42/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
2008-09-032008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-2/+2
* sp07/system.h, sp07/tcreate.c: Convert to bool type.
2008-02-012008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-1/+1
* sp01/init.c, sp02/init.c, sp03/init.c, sp04/init.c, sp05/init.c, sp06/init.c, sp07/init.c, sp08/init.c, sp09/init.c, sp11/init.c, sp12/init.c, sp13/init.c, sp14/init.c, sp15/init.c, sp16/init.c, sp17/init.c, sp19/init.c, sp20/init.c, sp21/init.c, sp22/init.c, sp23/init.c, sp24/init.c, sp25/init.c, sp26/init.c, sp28/init.c, sp30/init.c, sp31/init.c, sp32/init.c, sp33/init.c, sp37/init.c, sp38/init.c, sp39/init.c, sp40/init.c, sp41/init.c, sp43/init.c, spfatal/init.c, spfatal_support/init.c, spsize/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
2007-12-202007-12-20 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-2/+1
* sp07/task1.c, sp34/changepri.c, sp35/priinv.c: Add rtems_task_self() directive instead of violating RTEMS internals.
2007-12-192007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill4-6/+69
* sp07/init.c, sp07/system.h, sp07/tdelete.c, sp07/sp07.scn: Add test cases for User Extension Manager to improve code coverage. * sp21/task1.c: Fix spelling error.
2007-12-132007-12-13 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill3-6/+16
* sp07/init.c, sp07/sp07.scn, sp07/task1.c: Add tests for using notepad with the current task's ID or SELF * sp09/screen02.c, sp09/screen04.c, sp09/sp09.scn: Add test missing test cases for clock_get.
2007-11-272007-11-27 Glenn Humphrey <glenn.humphrey@OARcorp.com>Glenn Humphrey2-14/+13
* sp07/sp07.scn, sp07/task1.c, sp09/screen01.c, sp09/screen05.c, sp09/screen07.c, sp09/screen10.c, sp09/screen12.c, sp09/screen14.c, sp09/sp09.scn, sp25/sp25.scn, sp25/task1.c: Added several test cases to improve test coverage.
2007-05-112007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2-6/+4
* sp01/Makefile.am, sp02/Makefile.am, sp03/Makefile.am, sp04/Makefile.am, sp05/Makefile.am, sp06/Makefile.am, sp07/Makefile.am, sp07/tdelete.c, sp08/Makefile.am, sp09/Makefile.am, sp11/Makefile.am, sp12/Makefile.am, sp13/Makefile.am, sp14/Makefile.am, sp15/Makefile.am, sp16/Makefile.am, sp17/Makefile.am, sp19/Makefile.am, sp20/Makefile.am, sp21/Makefile.am, sp22/Makefile.am, sp23/Makefile.am, sp24/Makefile.am, sp25/Makefile.am, sp26/Makefile.am, sp32/Makefile.am, sp33/Makefile.am, sp34/Makefile.am, sp35/Makefile.am, spfatal/Makefile.am, spsize/Makefile.am, spsize/size.c: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
2006-07-11Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius1-4/+2
2005-11-13Convert to use *_PROGRAMS.Ralf Corsepius1-12/+9
2005-11-11Rework.Ralf Corsepius1-29/+8
2005-11-11Eliminate TEST.Ralf Corsepius1-7/+6
2005-11-11Expand sptests.am.Ralf Corsepius1-1/+21
2005-11-10Eliminate DOCTYPES.Ralf Corsepius1-2/+1
2005-11-09AM_CPPFLAGS += -I..../support/include.Ralf Corsepius1-0/+2
2005-11-07Remove SRC, PRINT_SRC.Ralf Corsepius1-2/+0
2005-11-07Switch back to include compile.am instead of amcompile.amRalf Corsepius1-1/+1
