path: root/testsuites/sptests/sp04 (follow)
* removed post switch extensionJoel Sherrill1996-02-131-1/+0
* SPARC port passes all testsJoel Sherrill1995-10-301-5/+5
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+43
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-233-3/+3
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-172-5/+3
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-2/+2
* Initial revisionJoel Sherrill1995-05-118-0/+426
