* | 2002-03-20 Chris Johns <ccj@acm.org> | Joel Sherrill | 2002-03-20 | 1 | -1/+1 |
| | | | | | | | * PR145. * sp04/task1.c, sp04/tswitch.c: Test fails if other tasks present in system (e.g. driver tasks). Also exit on minimum number of switches not precise number. | ||||
* | Patch from Eric Norum to avoid printing from context switch user extension. | Joel Sherrill | 1998-06-12 | 1 | -1/+16 |
| | | | | The array is too long and needs to be shortened. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | SPARC port passes all tests | Joel Sherrill | 1995-10-30 | 1 | -5/+5 |
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 1 | -1/+1 |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | ||||
* | maximum number of messages removed and include statement cleanup | Joel Sherrill | 1995-08-17 | 1 | -2/+1 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+104 |
