path: root/testsuites/sptests/sp03/system.h (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-4/+4
* Increased stack space for a task.Joel Sherrill1999-11-011-0/+2
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+23
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-111-0/+30
