path: root/testsuites/sptests/sp01/init.c (follow)
* Increased stack space for task 1.Joel Sherrill1999-11-011-1/+1
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-4/+1
* Initial revisionJoel Sherrill1995-05-111-0/+89
