* | 2000-10-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-10-27 | 1 | -1/+1 |
| | | | | | | * Makefile.am: ACLOCAL_AMFLAGS= -I $(RTEMS_TOPdir)/macros. Switch to GNU canonicalization. * sptests.am: Remove DEFS. | ||||
* | Thread iterate not ready for submission -- removed. | Joel Sherrill | 2000-06-14 | 1 | -1/+1 |
* | Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine Gauthier | Joel Sherrill | 2000-06-12 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860 | ||||
* | First attempt at adding simple binary semaphore in addition to the current | Joel Sherrill | 1999-12-13 | 1 | -1/+2 |
| | | | | | "mutex" and counting semaphore. This is at the request of Eric Norum and his EPICS porting effort. | ||||
* | Converted to automake. | Joel Sherrill | 1999-11-22 | 1 | -9/+3 |
* | Added new test sp28 to test the task variable directives. | Joel Sherrill | 1999-11-11 | 1 | -1/+1 |
* | rtems_semaphore_flush test from Eric Norum <eric@cls.usask.ca>. | Joel Sherrill | 1999-11-10 | 1 | -1/+1 |
* | Added sp26 which tests the rtems_task_is_suspended directive. | Joel Sherrill | 1999-10-25 | 1 | -1/+1 |
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -4/+4 |
| | | | | where wrapup left pieces out of the librtemsall.a. | ||||
* | New configuration files added by patch from | Joel Sherrill | 1999-08-10 | 1 | -0/+21 |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>". |
